how hard to replace front carpeting?
Considering replacing front carpeting on my 65 Coupe.
I'm really not handy but thinking it might be doable though: removing the seats and central console would suffice to replace it??
The most difficult and dirtiest part of the job was cleaning the floor pan of the adhesive and pad left behind from the previous install. My new pieces fit very well and it's hard to put them in the wrong way. My only alignment problem was the gas pedal bolts. I used Dynamat plus the jute backing and insulation in my 63 five years back and it still looks good. It was purchased from Willcox. You've got the list. Now get started.....lib
PS - cut your carpet a little larger than you think and do a final trim when you have it in place.
lots of luck ,doing mine on my 63 coupe 18 pices ouch---start from the back forward .if you have old carpet number them as you remove them look for over laping carpet.seat belt bolts two came out hard the other two i had to drill out not fun.i used everything there was to loosen them even freeze them .gonna finish the driver side on sat ,don ,t remember where the pedal block is placed top or bottom of carpet? any one knows-this a great site,thanks to all for the past articles.
Cut out slot for the block in the insulation/padding and the block mounts directly to the floor under the carpeting. No padding between the block and underside of carpet. This keeps the carpeting nice and even across the heel protector at the pedal.
Tom
Tom
Luckily, OP is working on a Vert and just wants to do the front. My 64 Coupe took ?? days due to lots of project creep (insulation, fiberglass repairs, loose rivets, stiffner repair ect...).
