Odometer on '61 quit turning
Old 09-25-2013, 06:45 PM
abdo
abdo's Avatar
2016 C1 of Year Finalist
Default Odometer on '61 quit turning
The odometer on my '61 was just turning to 10,000 miles (actually 110,000) and it stopped turning just as the 9999 was going to 10000.
It has worked without a problem since I have owned the car. The speedometer portion works OK.
Any ideas as how to fix it?
Old 09-25-2013, 07:48 PM
Mike67nv
Mike67nv's Avatar
2018 C2 of Year Finalist
2015 C2 of the Year Finalist
Sounds like one of the classic C1/C2 odometer problems. Dirt combined with dried grease will cause the odometer to either freeze or create so much resistance that something else gives (usually one of the gears). It sounds like you’re going to need to disassemble it and have a look.
Old 09-25-2013, 07:55 PM
AZDoug
AZDoug's Avatar
Received 1,478 Likes on 905 Posts
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
Have your entire speedo and tach rebuilt.
Two months after you replace the ODO, either the speedo or tach will quit working,and as you will find out, taking the cluster in and out is not a job, you will want to do again, real soon.
Doug
Old 09-25-2013, 08:17 PM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
Doug
Pretty much!
Old 09-25-2013, 09:13 PM
abdo
abdo's Avatar
Doug
I took the cluster out and had the tach and speedometer rebuilt several years ago. I know it is a frustrating job. In case it is the odometer drive gear, I see that Corvette Central sells a metal one for $11.95. Have any of you tried to replace the gear yourself? Or do I need to send it out?
Old 09-26-2013, 06:16 AM
rich5962
rich5962's Avatar
If the odo gear has damaged gears, then the main gear is likely the same. The main gear/magnetic bar can be changed, but you'll have to have it magnetized and calibrated. Replacement main gear magnets available today are NOT magnetized. They are a different shape as well.
Below is a example from a '67. After I rebuilt it with new odo and main gears, it was dead. Realized the magnet wasn't alive.
Called Bill Harrison (Harrison Speedometer) and brought it over for his magic. He's about an hour from me. He has all the good stuff to make these work. Worked perfectly after he finished it up.
If you're going to take it out, best to send it to the shop for full rework. This is one of those tasks you want once and once only.
Rich
Old 09-26-2013, 07:38 AM
63atlast
63atlast's Avatar
Replaced mine a couple of years ago and it has worked just fine. Replacement is easy...getting the cluster out is the hard part.
To Odometer on '61 quit turning
Quick Reply: Odometer on '61 quit turning
