1963 Corvette Front Axel Weight
Old 09-28-2013, 02:41 PM
Charliebates
Charliebates's Avatar
Default 1963 Corvette Front Axel Weight
I'm looking for the front axel weight on a 1963 etc Corvette w a 327.
I found the total curb weight is 3150 and the same for the coupe and the convertible.
Thx John
Old 09-28-2013, 03:29 PM
JohnZ
Support Corvetteforum!
JohnZ's Avatar
Received 1,857 Likes on 1,100 Posts
Thx John
Weight distribution front/rear is 49/51 on a coupe and 48/52 on a convertible, so the front weight is 1543# on a coupe and 1512# on a convertible; '67 small-block Engineering data, same as '63.
Old 09-28-2013, 11:09 PM
Charliebates
Thx & much appreciated.
John in Red Deer
Old 10-18-2013, 11:27 AM
Charliebates
The Berlina front axel weighs 1505# so I'll be going with the 1963 Corvette convertible coil spring with a comparable front axel weight of 1512#.
I presently have the stock 1982 coil spring at 460# (it takes 460# to drop the spring 1")
No wonder it rides hard. That's 250 pounds lighter on the front suspension.
I'm looking for the pound rating of the OEM 1963 Corvette convertible front coil spring so I can place the order for the matching spring.
Can anyone tell me where to find this info?
Thx, John
Last edited by Charliebates; 10-18-2013 at 11:35 AM. Reason: to clarify information
Old 10-18-2013, 04:55 PM
JohnZ
JohnZ's Avatar
Thx, John
1963 linear-rate front springs were one-year-only. The 1964-'67 small-block front springs (#3851100) were progressively-wound variable-rate, from 195 to 295 pounds per inch, and were 9.98" high at 1340# load; they were .600" dia. wire, and 3.80" inside diameter, and 16.82" free height.
Old 10-19-2013, 11:00 AM
Charliebates
Right on. Thx & much appreciated. John
Old 10-19-2013, 05:45 PM
DucatiDon
DucatiDon's Avatar
C2 of Year Finalist (performance mods) 2019
2018 C2 of Year Finalist
Any pics of the 63 spring alongside the later spring?
Old 10-19-2013, 09:06 PM
JohnZ
JohnZ's Avatar
Here's the '63-only linear-rate spring on the left (note constant coil spacing), and the '64-up #3851100 variable-rate progressively-wound spring on the right (note closely-spaced coils at one end, changing to widely-spaced coils at the other end).
Old 10-19-2013, 09:33 PM
DucatiDon
DucatiDon's Avatar
Thanks John.
To 1963 Corvette Front Axel Weight
Quick Reply: 1963 Corvette Front Axel Weight
