Help identify this C2 air cleaner
Old 09-30-2013, 01:55 PM
ohiovet
ohiovet's Avatar
2016 C1 of Year Finalist
Default Help identify this C2 air cleaner
Air cleaner appears to be for a 1965 or 1966 high performance 350 or 365 HP engine.
It has the large crankcase vent tube to the valve cover (or other crankcase vent location) but I am not sure what the small tube connector is for.
Could it also be for a big block application?
Old 09-30-2013, 02:08 PM
Mike Geary
Mike Geary's Avatar
64-65 365hp and 65 350hp.
Small fitting is for the choke air intake hose.
63 340hp is similar but lacks the choke hose fitting (connects directly to AFB).
Old 11-08-2021, 07:05 PM
ScottGPM
Learning to Restore a C2
Support Corvetteforum!
ScottGPM's Avatar
Newbie here...does this come apart for cleaning?
Old 11-08-2021, 07:09 PM
Nowhere Man
Nowhere Man's Avatar
Received 6,920 Likes on 4,770 Posts
2015 C2 of Year Finalist
The lid comes off the base
Old 11-08-2021, 07:10 PM
ScottGPM
ScottGPM's Avatar
Seems mine is stuck together like its been glued shut. Thanks!
Old 11-08-2021, 07:27 PM
Redbird
Redbird's Avatar
2021 C2 of the Year Finalist - Unmodified
C2 of Year Finalist (stock) 2019
2016 C2 of Year Finalist
Someone probably used a paper element filter with the rubber ring and it is sticking together. Just give a tug on the lid.
Old 11-08-2021, 07:35 PM
68hemi
68hemi's Avatar
Received 3,048 Likes on 1,934 Posts
C1 of Year Finalist (performance mods) 2019
Correct and to answer the rest of it ALL midyear BBs used an open element air cleaner.
Old 11-09-2021, 10:27 AM
CorvetteMikeB
CorvetteMikeB's Avatar
Just drop it on the garage cement floor a coupe times, that should work it loose.
Dave64 (11-13-2021)
Old 11-09-2021, 02:56 PM
Easy Rhino
Easy Rhino's Avatar
Received 1,918 Likes on 1,332 Posts
The black silk screened lettering is shown as correct for late 64 and all 65 350 and 365 hp 327s.
The repos are spendy and this one looks in nice shape.
vettefred (11-09-2021)
Old 11-12-2021, 02:50 PM
ScottGPM
ScottGPM's Avatar
Well a lot of wd40 did allow the top to loosen up and it pulled apart. Was loaded with a foam filter and all of it may have been original to the car.
Thank you everyone! Polished, cleaned up and going to go back on this weekend. Got to get it running again and try out the new Hurst shifter.
Redbird (11-13-2021)
To Help identify this C2 air cleaner
Quick Reply: Help identify this C2 air cleaner
