C1 front suspension
2023 Restomod of the Year Finalist
C1 front suspension
i've got a squeaky front end, so I assume I need to replace upper & lower bushings in the A frames or towers. Thought I'd start with the uppers first.
Is this something that can be done by an old worn out shade tree mechanic with no special tools?
Received 3,769 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
Nt,nokma,n.
You're going to do a complete front end rebuild because of a squeak ?
Try lubing all 22 (24 lube points if you have Zerk fittings on the U-joints) first.
Hit the front fittings with the weight of the car ON the wheels and again with the weight off the wheels (e.g. wheels hanging free). You might just find your squeak is gone.
It worked on my car.
I'll wager all of those 6 locations are very dry.
ALL of the above information is good. BUT, if ANY of the front suspension joints in a 53-62 Vette are squeaking, that means they are dry. Thus, that means they are now metal-to-metal. As a result, DEPENDING ON HOW LONG they have been squeaking and wearing, then is is quite possible some (or a lot) of slack in the joint(s) has occured. This slop will (or can) significantly effect alignment and result in poor handling.
As a friendly reminder:
The Owner's Manual specifies greasing the front suspension (all 22 fittings) every 1000 miles.
And recommend you use a good quality EP grease with moly.
Plasticman
Plasticman
