Temps up or temp gauge weirdness ?
So I have been driving the 327/300 (all stock original motor) for more than a year now. The temp gauge always sits at the "1/4" mark half way between 100 & 180, only ever saw it approach 180 once on a hot day, but it never moved past there..... until last week !
Now the car quickly comes up to the 180 mark and hovers around it much of the time... I parked the car for about 20mins and came back, when I started it, the gauge was at "3/4", but after driving off moved back down around 180....
I checked with IR gun, top of radiator, thermostat housing are actually at 180, much of the intake is too although some spots were closer to 200.
So, all of a sudden my temp gauge is dynamic or am I actually running hotter than before.... hard to say !
The temperatures you are seeing now are more typical than what you read before. If it agrees with the IR gun, even better.
Mine in my '64 flips occassionally. As stated in a post I had a week or so ago, I went to a car show about 3-5 miles from my house and before I got to it the car was registering 220-240 on the temp gauge. Had me concerned. After the show I fired her up, the gauge ran 180. I I.R.d the engine and all the temps were below it. The next day I took a 2 hour drive both ways, and the gauge never moved off of 180. There was approximately a 2 hour gap between each way.Go figure.
Yeah I felt a bit better after I got home and pointed the IR gun at it. I was a little concerned that it read around 210 after the brief stop, but I guess realistically the temps at the top of the motor would climb straight after shutting it off right ? I had never seen the gauge so high !
