1967 vent window rubber
There is a piece of rubber that fits the vent window into the chrome frame. It basically wraps around the window and snug fits into the frame. Where can I get that part?
All of the vendors have it. http://www.parts123.com/parts123/yb....Z5Z5Z50000050B Make sure that you get a left/right, and coupe/convertible. There is another straight piece that runs along the rear edge of the glass.
Mike Coletta
Mike Coletta
I think he's talking about the part around the glass into the actual vent frame, not the vent frame strip that mounts to the door jamb. Maybe OP could clarify?
Once you measure your glass thickness and the frame channel width, you will know which thickness to get.
I've always been able to find it at auto glass shops.
Buy extra!! You will probably mess up the dart cut in the corner the first time.
Somewhere there's info on a simple jig that uses a B&D Workmate to press in the glass with great control. Best method I've seen.
The material is usually referred to as "glass setting tape". It comes in different thicknesses, and also different compositions. Rubber or impregnated fabric.
And to the other responders... yes, I'm looking for the part between the glass and chrome not the full surround weatherstrip.
