1960 re wire done - alternator question
Just installed a new lectric harness, everything is working except the ammeter.
Car has been converted from gen to alternator by PO.
I have a Borg Warner external voltage regulator/alternator system on a 350 Chevy in my 1960 Vette.� I have 12 volts to the red wire on terminal 3, I have eliminated the brown wire to the dash light (not needed).� I am not getting 12V out of the terminals 1&2.� these terminals are blue/white to the alternator, correct?
any help is appreciated.�����
Thanks,
Thanks,
Founds these instuctions, does this make sense?
FYI Dist is not pertronix but has been converted to electronic.
Instructions
Switch off the engine of your vehicle and disconnect the clips of both the negative and positive terminals of the car battery. Turn the vehicle battery 180 degrees and connect the cable leading to the starter to the positive terminal of the battery under positive to negative ground conversion. Do not connect the negative terminal as you will have completed a circuit and electrical accidents are bound to occur.
Reverse the wires on the back side of the ammeter using a screw driver to connect the negative to positive terminal and vice versa.
Disconnect the wires connecting the tachometer (revolution counter) and remove it completely from the dashboard. Take the negatively ground tachometer and place it at the place where you had initially removed the other tachometer reattaching all the wires.
Reverse the connections on the ignition coil as this helps in preserving energy in the coil. The ignition coils terminals are usually marked with SW for switch and CB for contact breaker and hence will not be difficult to locate.
Check again to verify everything is switched off. Upon completing the check up, reconnect the negative terminal of the car battery and switch on the ignition switch to verify everything is in order.
Thanks.
Instructions
Thanks.
Received 1,857 Likes
Instructions
Thanks.
Instructions
Thanks.
Thanks, I found them doing a generic google search that is why I thought I better ask. I have tried searching here but haven't been able to find an answer.
