1960 clutch pedal rod question
Old 10-15-2013, 08:01 PM
pwilks
pwilks's Avatar
Default 1960 clutch pedal rod question
The clutch pedal rod has a seal and a seal retainer that screw into the firewall. Do they screw in from the engine side of the firewall or from the clutch pedal side? I have seen it both ways in different catalogs and this page on my assembly manual is not legible. Also, does the hole in the seal/retainer run horizontally or vertically? Again, I have seen it both ways, but vertically seems to make more sense. Thanks.
Old 10-15-2013, 08:23 PM
62corvette
Support Corvetteforum!
62corvette's Avatar
Vertically. And screws installed from the inside of the car.
Old 10-15-2013, 08:43 PM
62Jeff
62Jeff's Avatar
But it appears to be dependent upon the year, which is probably why the catalogs show it different ways.
A good recent discussion is here
http://forums.corvetteforum.com/c1-a...-firewall.html
Old 10-15-2013, 10:56 PM
pwilks
pwilks's Avatar
Thanks guys. Previous thread clears it up. Doesn't really matter - some years it went inside, some outside (but hole is vertical).
To 1960 clutch pedal rod question
Quick Reply: 1960 clutch pedal rod question
