Barry Toycraft corvette go cart
It would be my bad luck
that someone with one of these would move in at the end of my street!
have a Barry Toycraft frame with wheels, and original motor, needs restored any
Hi, new here, I have a Barry Toycraft frame with the tires and wheels, it is missing steering wheel, missing the sheet metal (no seat pan, no rear Pan), but has the "gas" AND brakes, rusty and needs restored, but complete pipe frame, also have the original electric motor, would like ballpark range as to value, I know without a picture it is difficult as condition is important but would like just a ball park fair range,it came with the original Toycraft belt which is not in good condition but the logo is on it,thanks
Second , anyone have a wiring diagram , the motor has the battery ground cable on it that is attached to the body, then it has 3 wire terminals, 2 on one side, that one yellow wire is attached to one and one black wire is attached to the other terminal, then on the opposite side of the motor is another terminal with a yellow wire attached, I would like to test the motor and need to know what the 3 terminals are for and their purpose Thanks
Last edited by tinybigsmoke; 08-17-2016 at 01:36 PM. Reason: needed to add additional info
Hi, new here, I have a Barry Toycraft frame with the tires and wheels, it is missing steering wheel, missing the sheet metal (no seat pan, no rear Pan), but has the "gas" AND brakes, rusty and needs restored, but complete pipe frame, also have the original electric motor, would like ballpark range as to value, thanks
tinybigsmoke (08-17-2016)
