327 / 383 Question
327 / 383 Question
A question for the engine builders and machine shop gurus here....
If I wanted to build a 383 with a 327 block (in order to maintain the road draft tube and factory PCV setup...its a 63 340hp) are 2 bolt mains strong enough? Is it worthwhile to machine a 327 for 4 bolt main caps? Any issues one should be aware of looking for a good 327 candidate block?
I want a healthy motor, but nothing over 500hp, and no juice.
I can get a custom small journal crank......just trying to decide if I want to waste my time with the 327 block or not.....
It is important to me to try to keep the car looking as original as possible...
There were some 2 bolt and some 4 bolt 400 blocks cast, so 2 bolt has worked and been proven with a 3.75" stroke.
You might look for a, I think, 1968 (one year only) 327 which had large journals, and save money on the custom crank.
I'm building a 385 (.040 over) right now using 327 service replacement block(3959512)I had the block align bored for the 350 main bearing, using a scat crank and 2 bolt mains with arp studs.(looking for 400 -425 hp).
Scott, No, the bottom of the 3959512 is just like a 350.I had the block clearanced at the bottom of the cylinders and at the oil pan just like a 350 .
Ive been looking for a CE 512 block, but cant seem to find one.
Its the clearancing I guess that concerns me....hate to ruin a good block....
Here's a pic of the crank in the block.
Here's a pic of the main before align bore. The block main is notched for 327 and 350 bearing.
Received 1,857 Likes
Yup - you want to avoid that - photo below shows what happens when you get just a LITTLE too aggressive with the grinder; it's a block one minute and scrap iron the next.
Ha to have the raid draft tube hole in the back of the block....if it does let talk
Hitch
Received 3,043 Likes
St. Jude Donor '05
Id grab a 350 block and see what you can do about the draft tube thing to make it work.
Wesmigletz did this and if I remember right didnt seem worth the money
Wes stroked his 283 out to 377 ci and I believe he is very happy with it. He also stroked his 327 out to 396 and added AFR heads and a roller cam which really kicks ***. He spent a lot on machine work installing the 4 bolt ProGram main caps.
St. Jude Donor '05
Wondering why machinists dont regularly pin the caps sure would help with 2 bolt builds with cap walk...even 4 bolt
