windshield caulk
Old 10-27-2013, 10:30 PM
SS409
SS409's Avatar
Default windshield caulk
Did the factory ever use any type of caulk between the reveal molding and the windshield gasket on a 66 coupe?
Old 10-28-2013, 02:27 PM
JohnZ
Support Corvetteforum!
JohnZ's Avatar
Received 1,857 Likes on 1,100 Posts
Yup - 22 ounces of it (see your A.I.M., UPC 1-Asm, sheet F22).
Old 10-28-2013, 08:24 PM
SS409
SS409's Avatar
Thanks John. With that much caulk it would seem like it would be a messy job to get the molding secured to the clips. What caulk should I use for this? Do you have a 3M part number?
Old 10-28-2013, 09:30 PM
6T5RUSH
6T5RUSH's Avatar
Cruise-In III Veteran
SS409,
I'll chime in here and tell you that you want 3 M 08609, Window-Weld, Super-Fast Urethane. This product is used after the windshield with a new weatherstrip is installed. This product will harden up and become the "glue" between your rubber and glass. This is a urethane. I also used strip caulk, 3 M Strip Calk 08578 to also seal the stainless on the windshield frame itself.
Here's a link to my DIY windshield install:
http://forums.corvetteforum.com/c1-a...d-install.html
Good luck!
Jim
In God We Trust!
Old 10-29-2013, 03:48 PM
JohnZ
JohnZ's Avatar
I don't know that I'd use the WindoWeld urethane - when it cures it may be next to impossible to get the reveal moldings off. 3M #08509 Automotive Bedding & Glazing Compound works well for this application.
Old 10-29-2013, 06:45 PM
65 Pro Vette
65 Pro Vette's Avatar
Received 1,045 Likes on 576 Posts
C2 of Year Finalist (appearance mods) 2019
The urethane is used between the rubber and glass
To windshield caulk
Quick Reply: windshield caulk
