66 327/300HP Holley Carb
Is the thin stainless steel spacer between the Holley carb and intake manifold necessary? If so does set on the manifold or between gasket and carb?
Received 1,856 Likes
Yes, it's necessary, to keep the hot exhaust gases in the "hot-slot" from melting the carb baseplate; it goes as shown in the Assembly Manual, between the gasket and the carb base. Recommend plugging the holes at the end of the "hot-slot".
What do you plug holes in "hot slot" with.? Thanks
