to pulg intake or not
after i drive my car 65 corvette 300 hp 327 and if i let it heat soak it will act like its loading up bad like the carb is leaking down if you look down the carb you can see no dripping once it cools off it will run fine i have a rebuild kit for the carb coming but should i plug the 2 holes in the intake under the font of the carb when it is off? will this help with heat on the gas and carb in Arizona we really don't need any more heat . and if so whats the size of frost plug to use thanks
St. Jude Donor '07
the best way to do it is to remove the intake and use FI intake gaskets that block off the crossover at the head/intake interface. but, plugging the holes under the carb is better than nothing.
make sure your heat riser valve is wired open or knock the butterfly out or use a FI spacer
Bill
Bill
Make sure you have the correct gaskets under the squirters. I fought that problem after an "expert" rebuilt my carb.
There should be no drips even when its hot.
Jim
Jim
Living in Arizona, it would certainly help to block your crossover. Keep in mind that if you do, you will need an H or an X pipe to re-tie your exhaust together again.......unless you can live with that funky exhaust sound. After I blocked my crossover off, a muffler shop installed a H pipe behind my tranny for 100 dollars. I also removed the heat riser, and installed a FI spacer.
