Replacing engine mounts on my '63
Got to replace the engine mounts...can I safely just jack up the engine from underneath enough to replace these mounts. If so, where should my jack point be? Harmonic balancer? Oil pan (got a 6 quart pan so it is not flat across the entire bottom)? Exhaust manifold? Or somewhere else? Thanks for your advice. I know many of you have already done this.
Received 1,857 Likes
Received 1,843 Likes
I think the easiest way is to take either through bolt out of a motor mount, jack the engine just a scosh to get enough clearance to slide the mount out. Do one side at a time.
[QUOTE=MikeM;1585364755]I think the easiest way is to take either through bolt out of a motor mount, jack the engine just a scosh to get enough clearance to slide the mount out. Do one side at a time.
From the Japanese word "sukoshi," pronounced skosh. That also means a little bit.
