63 250 hp water pumpe
Is this a 'long' or 'short' water pump ?
The Vintage Air guy asked me the question and told me if there was about 3/4" between the front of the timing chain cover and rear of water pump it is a "long" pump. It makes a difference in what he orders !
St. Jude Donor '07
Frank
interesting... after the earlier thread on adding an alternator, and whether there was ever a 'lonnnnng' pump used in a corvette (JohnZ says 'never'), then it must be a short pump. besides it has the bypass fitting on the top....
what does it measure between the timing cover and the back of the WP?
if a long pump was never used, then why order an a/c setup for a long pump... pumps are easy to change.
Bill
Bill
Received 1,857 Likes
That's a "short" pump, but it's a Service replacement with a bypass, which was only used on the solid-lifter engines; the 250 and 300hp engines used a non-bypass pump.
The OEM bypass pump had a smaller diameter bypass fitting.
When passenger cars went to the "long" water pump in 1969, they also got accessory drive mounting holes in the ends of the cylinder heads, as the right-hand alternator mounting was an entirely new design (which was never used on Corvettes).
Thanks all. Fixed it with the Vintage Air vendor; he's ordering the short pump stuff.
