Ethanol treatment with Octane boster
What are you guys with Small blocks and original Carbs doing
with treatment to help with contamination during the cold weather
till spring. I am breaking a new 300 HP with original 461 heads and a
stepped up cam ,I added the Ethanol treatment from Lucas but reading about it some treatments like Star Tron says be carful what treatment you use that may contain alcohol. Doesn't Octain booster contain
alcohol.
alcohol.
Contamination from what ?
I have two Corvettes; one with dual quads, the other with a single and don't add anything; drive on 87 octane ethanol 24x7x365. My carbureated boat (stored outside all winter) runs on the same gas and gets a little Sta-Bil each year (and yes you can get several days in a row with temps in the 20s down here). That's it.
You'll drive yourself nuts with the Snake Oil additives.
Received 1,843 Likes
My '67 327/350 L79 absolutely MUST have SOMETHING - just the way it is. All the usual tuneup stuff, Quick Fuel carb, Cool Carb heat plate, etc. - plus mine is an original TI car too. I run Torco Fuel Accelerator - 16 ounces/fill-up; my research indicates that this seems to be the best, least intrusive product - it ain't cheap though...
Since ethanol IS alcohol, I wonder why adding MORE alcohol is good if alcohol is bad.
Many of us here have been using E10 fuel for years or decades. In my case, over 20 years. No one has yet reported any storage problems with old Corvettes. Only some guys in FL or Gulf states seem to have operational problems.
No snake oil additives required.
Bill,
Not to steal this thread but what is so good about Marvel Mystery Oil?
I know it's been around forever and a day but, what is the benefit from adding it?????????????
I ask this hoping you're not a stock holder just trying to up your 401K
You can PM me if you don't wish to post your reply here. And now back to our regularly scheduled thread of snake oil.......
What we need to know about Ethanol blended fuel
Debris in fuel
gums rapidity in fuel tank and delivery systems as ethanol ages
ethanol fuels break down quickly, fuel loses octane and becomes
stale hard starts, pinging, knocks
Star Tron is a powerful fuel stabilizer to help to stop fuel breakdown.
also say This stuff breaks apart large clusters of fuel molecules
creating more surface area this allows additional
co2to react during combustion keeping carbuators clean -www.startron.com That's how they say this stuff works
Debris in fuel
Cut and paste from some advertising hype.
Just send me the money each week you would normally spend on this stuff and I will immediately send you an email stating, "Everything is OK!".
The effect on your wallet and mental health will be the same and your car won't know the difference...
Debris in fuel
Debris in fuel
I don't believe there is any known chemical additive to reconstitute gasoline that has suffered "phase separation" as explained above.
The best thing to do, (and the cheapest) is to keep water out of gasoline to start with and if you have doubts about yours, drain a quart or so out in a clear jar and let it stand for and hour or so. If it's clear, top to bottom, you have nothing to worry about. If it's dark and/or cloudy or you can see distinct layers, throw it away. You can't save it.
There is no reason to expect gasoline that has sat in a sealed tank over the winter not to be perfectly good and usable six months later. But problems can start if you leave the container unsealed and open to atmosphere.
Received 1,856 Likes
Debris in fuel
Debris in fuel
Non ethanol gas with water in it has many of the same negatives that ethanol gas with water in it does does but one difference is, you water is constantly being absorbed everytime you replenish the gas used out of your tank. Regular gas, the water just keeps increasing until a slug of it goes through your carb and kills the engine.
Anybody here that is old enough to remember leaded gas might tell you that it was the greatest stuff going. Others will tell you lead is the worst possible thing they ever put in gasoline. Then there was unleaded gasoline. Dire predictions of the end of the world. And now, the non-performing and incompetent mechanics and the carnival snake oli hawkers have E 10 to kick around. Wonder what's next?
FWIW, ethanol will hold only so much water and then it will fall out of suspension in your tank. What settles to the bottom, your engine won't run on. The next layer up is a mixture of water, alcohol and gasoline. Your engine will run on this mixture but not really well. The top layer is fine to run on as it's pure gasoline but has now lost the octane additive of the alcohol because the weight of the water mixed with the alcohol has pulled it out of suspension with the gasoline.
\all I wanted to know if other people have this problem I live in Delaware and Ethanol is in the Gas .
Purchased a new lawn mower and the mechanic showed me what
Ethanol does to engine parts I said I have a corvette engine I am breaking in he said gas these days breaks down a lot quicker
due to the 10% Ethanol the parts were all black and gummy.
Received 3,043 Likes
St. Jude Donor '05
Dont even worry about it.
I let mine sit for months at a time unfortunately stale gas or not it drives fine (11.5:1) I just dont hammer on the right pedal til I get some good stuff in it.
If anything it makes good week killer lol
Again- over 20 years experience here, never a problem.
Forget what people tell you about their boats, weedwackers, lawmowers etc. They've ALWAYS had problems. That's why they invented Seafoam in the 30's, long before ethanol.
St. Jude Donor '07
Bill,
can't prove it, just think it...
http://www.marvelmysteryoil.com/inde...site/faq/#fuel
Bill
