Need help with Engine ID
'66 coupe - NOM. Casting appears to be a 350 block with a casting number of 3970010. Stamp pad read:
K01 21 H or 11
That's all I could get off of the pad.
All help appreciated.
K01 21 H or 11
010 blocks are supposed to be a higher nickel content than others. Some say it's not any stronger but who knows! Just my 3 cents!
3970010 is probably the most common casting number block ever issued by GM, there's millions of them around.
As the other poster mentioned, an assembly code that starts with K would be for the McKinnon Industries plant in St. Catherines Ontario.
