Roller pilot Bearing Removal Experts
Unfortunately I fitted a roller pilot bearing and it has failed!
I have removed the old bronze bushings in the past with grease a piece of dowel, no worries.
However I cannot get the needle bearing type to move out!
Has anyone solved this problem?
I'll be replacing it with the bronze type.
Gary
Perth West Australia
Gary
Thinking that a rollerized pilot bearing was the best thing since 'sliced bread' I added one to my 66 smallblock Coupe. Problems cropped up and pointed to a wasted bearing. Here's a shot of what mine looked like alongside a new roller bearing.
By the way, I used the GM version which has more rollers than the aftermarket version but it didn't seem to help. To remove the remnants, I wound up using a Blind Bearing Puller and found a cheap set at Harbor Freight.
Mike T.
Mike T.
Received 3,772 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
I have posted this picture before.
Here is what can happen to the pilot (right) on the end of a tranny input shaft when a roller bearing fails.
Now, with that said, If a roller bearing is used-----------------about the best and only insurance against failure is to THOROUGHLY pack the rollers with TOO MUCH grease.
Mike T.
Mike T.
Same exact tool I used.
Received 2,127 Likes
This "roller vs solid bronze bushing" thing has been out there quite a while. 20 months ago I pulled my eng/trans and replaced my cl/pp/tob. I did not replace my GM bronze bushing that had been in place since '85 I think. It may well be the original since my memory is not that great WAY BACK then of having changed it. At the very least, I have 104K miles on the current one. If it is the orig, it has 217K miles. I think this my prove the point that the bronze bushing is the right thing to use. Dennis
Received 3,043 Likes
St. Jude Donor '05
id use a bushing anyway how would they know
I bought the GM fluted pilot bushing they measure out absolutely perfectly better than the Milodons Ive been using. Just had 1300 of trans work done due in part to a tight fitting pilot bushing.
Spend 10 bux and get the good one.
Interesting story Jack, in Australia we would call the bearing a"Bloody Mongrel of a thing!"
I am trying the tap & bolt method today and if that doesnt work I'll have to source a bearing puller like you used.
wish me luck,
Gary
wish me luck,
Gary
Good luck - it's never a dead end, you just might have to escalate to the next level!
Success!
Bought a Blind Pilot Bearing puller from the local Auto parts store and out it came. Only cost $AU35, made in Taiwan but it did the job.
Took two attemps, first pulled out the roller cage and the second pulled the bushing out.
Gary
Gary
