336 or 355
336 or 355
anyone running a 355 or 336 gear with a M21 closeratio 4 speed. I now have a 411 but is too low for any distance, would like to change without losing all of my torque, Thanks, Jackie
Received 3,772 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
Could you post the gear ratios for the tranny? I just put in a zz4 with a TKO 500 and I have a 3.36 in my 66. I dont have the seat of the pants acceleration I am looking for. I am leaning towards changing to a 3.70 or 4.11. I think with the overdrive I get around the high RPM's In 4th. the more real life expirences with 3.70's or 4.11's, the easier the choice becomes. currently there are a bunch of threads going on right now concerning rear end ratios - some wanting more pop and others not liking highs revs at highway speeds. doesnt seem like it should be so tough with an overdrive - yet there are a lot of people looking for an answer
2.20 1st gear
1.64 2nd gear
1.28 3rd gear
1.00 4th gear
You can change it to an M-20 wide ratio: 2.52.; 1.88.; 1.46; 1.00 just by changing the main drive gear and the countergear.
1.64 2nd gear
1.28 3rd gear
1.00 4th gear
Received 1,857 Likes
You wouldn't like the 3.55 with that 2.20:1 low gear, and the 3.36 even less; if you had an M20, it works fine with a 3.36. There's no free lunch with 1st gear ratios and axle ratios - they either work together or they don't. If you want a highway traveling setup and good low-end torque, you need an overdrive transmission.
Received 6,529 Likes
C2 of Year Finalist (track prepared) 2019
The change muffled what had been explosive acceleration. Even so, I'm well pleased with the end result.
Jim
I swapped out the original 4.11's in my 63 about 6 years ago when I was living in Maryland. Put in a 3.55 pumpkin......... I did it to cut down on RPM's at highway speeds.
Changed the whole character of the car for the worse.
After I moved to Florida, I swapped again and put the original 4.11's back in.
I did not like the 3.55's in my car. Tough to accelerate from stop lights, had to feather the clutch, etc.
Now, I have my "old" car back with the 4.11's.
Chuck
Chuck
John Z is correct.
My car had the 4.11 rear end. I wanted to change for the same reasons as you. I quickly found out that I needed to change my M-20 from a close ratio to wide.
Yes, it is probably not as exciting to drive from a performance standpoint but I'm happy now to be able to drive the thing around and cruise.
Received 5,010 Likes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
It is NOT unique to this forum. I never understand people who ask a legitimate question----------------------------------and then disappear!
Oh well--------------
This question, or frequently very similar type questions (engine/gearing combinations) often arise. And there are as many opinions as there are combinations.
I would truly prefer a 4.11 or 4.56 for fun to drive reasons. But with the abundance of Interstate hiways (I clearly remember when there was no such word as Interstate, and only a FEW turnpikes), as well as the price of gas, a high gear rear (or at least an overdrive) seems to be the best solution. But with a high gear rear, you need a healthy torque motor, or a tranny with a very low 1st gear. Big blocks make great torque motors, but I don't like the added frontend weight.
For me personally, the solution for torque is a BIG inch SB (383 at the very least) with very good flowing heads (alum is a plus for cutting weight) and an aggressive cam (hyd roller if it will fit into the budget). With a well built big inch SB which saves weight and produces plenty of torque, a wide ratio 4sp and a 3.08 rear makes a great combination. With that kind of combination, VERY MINIMAL clutch feathering is necessary (actually, almost none). The car still may not be a rocket from a dead stop, but once the rpm is above 1000-1200, you can be at 60-70mph with 1st gear in no time. Power shift to 2nd and you're suddenly looking at 100mph----------------------and only in 2nd gear!!!!! And yes, my 56 with a SB400 will do that.
My 383 has pro-filer alumn heads with 208 valves, 577 hyd roller cam, dynod at 535 Hp, should have enough TQ. I was just asking the question about a 355 because i'm turning way to many rpms at 70 mph with the combo I have. I would like to drive it out of the city limits. the only way for any period would be to drive about 55
M20/3.08 rear, or, leave the 4.11 in it and install a 5spOD.
