Hella Windshield Wiper Control Switch
Old 12-11-2013, 10:38 AM
batman1414
batman1414's Avatar
Default Hella Windshield Wiper Control Switch
Was checking old threads and was wondering if anyone has gotten this switch to work for delay of wipers. If so how did you wire it up
Hella Windshield Wiper Control Switches 001871041
Thanks 1964
Old 12-13-2013, 01:57 PM
MelWff
MelWff's Avatar
Received 1,816 Likes on 1,605 Posts
These are the instructions
http://ep.yimg.com/ca/I/classicgarage_2272_431392355
Old 12-13-2013, 03:00 PM
batman1414
batman1414's Avatar
Thanks does anyone know if the wiper switch is negatively or positively grounded (Also has anyone gotten this switch to actually work since it is over $70.. )
Thanks again
Old 12-13-2013, 03:09 PM
JohnZ
Support Corvetteforum!
JohnZ's Avatar
Received 1,857 Likes on 1,100 Posts
ALL Corvette (and any other U.S. cars since the 30's) are NEGATIVE ground.
Old 12-13-2013, 05:18 PM
batman1414
batman1414's Avatar
Thanks John for the info I will probably go ahead and order one
Old 12-14-2013, 07:43 AM
batman1414
batman1414's Avatar
latest update: I emailed another Forum member (Mikey) and he said that when he tried this switch the wipers barely move from the park position and then the delay circuit shuts off and they return to park before they fully wipe the windshield. So unless else actually got this to work and let us know the Hella Switch will not work. Thanks Mike for letting me know
Merry Christmas to all
Old 12-14-2013, 09:13 AM
1coolC2
1coolC2's Avatar
Here is an option if you would like delay wipers. Mounts in original firewall holes and requires NO permanent alterations to the car. Switch mounts in factory dash and uses original ****. Reliable motor with hi-low and 5 intermittent speeds. No washer function....like any of us use that anyway. Good option for a driven car.
R/
Jeff
http://www.detroitspeed.com/1963-196...wiper-kit.html
Old 12-14-2013, 10:27 PM
daverichey
6th Gear
daverichey's Avatar
If anyone has this switch and would like to recoup part of their investment, I'd be interested in it. I have a 1970 Mercedes I'd like to try it on.
Old 12-15-2013, 07:19 AM
6D2148
6D2148's Avatar
Not sure about 30's or 40's but 50's fords were positive earth 6v until 1956 when they changed to neg earth 12v
Old 01-24-2014, 12:14 PM
batman1414
batman1414's Avatar
Have found a solution and it works very well on my 64 ...uses original switch and module mounts under dash ..easy to install and very decent price.
http://www.revolutionelectronics.com...-wiper-module/
and they are excellent to work with
To Hella Windshield Wiper Control Switch
Quick Reply: Hella Windshield Wiper Control Switch
