Wiper motor help please
I removed the wiper motor assembly from my 65 coupe just to clean it up and make it look nice again.
Prior to removal the wipers worked fine.
The pump did not work but I don't care if it works or not.
I cleaned everything up but did not bench test it since I was concerned about getting it out of index ( not sure if that mattered or not).
Anyway, after putting it back in (and reinstalling the glove box) it WON'T WORK.
When I turn the **** to the first position I hear a click coming from the assemby but nothing happens.
When I turn the know to the second position, same thing, a click but nothing happens.
I looked at the wiring diagram and it looks like there is a relay built into the unit.
I unplugged and replugged the connectors but still didn't work.
Tried tapping...nothing.
It wasn't fun to remove so I would like some troubleshooting suggestions before I remove it again.
Besides, if I remove it and get it on the work bench I am not sure where to start.
Thanks for the help
Thanks for the help
Received 6,943 Likes
2015 C2 of Year Finalist
did you make sure the wiper transmission arms are on correct and not bound up
I would make sure it has a proper ground. Run a jumper wire from the wiper motor case to the negative battery terminal. Also, make sure the nut on the switch is tight as this connection is also a ground. Also check the ground wire to the gauge cluster and dashboard "Z" bar. You may have knocked it off while you were under there.
If all you did was R&R and it's making noise but not moving now, sounds like something in the linkage is bound. As mentioned above, try removing the connector and running a jumper directly to the motor. If you are still getting a humming sound but no movement, sorry but the motor will have to come out again to get to the bottom of it.
If you do have to go to the trouble of removing it, you really should take the cover off and clean out all the old grease. Even though mine worked, and I wanted to do a cosmetic restoration like you, it was amazing how hard some of that old grease had become. I used synthetic grease to re assemble.
Pilot Dan
Pilot Dan
Thank you to everyone who offered help.
Once agan the culprut was GROUND ISSUE
While doing all this testing I had the wiper switch dangling from the dash...i.e. not grounded.
I removed the motor tested it on the bench and it worked fine.
Finally studied the wiring diagram and then I realized what I was being told on the forum...CHECK THE GROUND
