C1 - What LS1 Oil Pan for Street Shops Chassis
I am building a 56 with a Street Shops Chassis.
For those who are using a C1 street shops chassis, what oil pan, front runner and exhaust manifolds did you use?
Thanks,
Thanks,
I have an art Morrison & I believe they are similar on the front, with that in mind I installed the holley oil pan rear sump & vintage air front runner, the headers also came from Morrison.
Did you call street shop? I've talked Trey a few times & was helpful. Usually had to leave a message & he called later.
Thanks!
one of these styles.
http://www.improvedracing.com/LS-oil-pan-dimensions.php
are you after short tube or long tube headers? If short tube are ok, you might take a look at these. I have a set that I'm using on my 59 BelAir swap and they are stainless steel beauties. come with collectors with 0-2 bungs already installed, plus you sure can't beat the price.
http://cgi.ebay.com/ws/eBayISAPI.dll...m=131083549200
Russ
Russ
are you after short tub or long tube headers?
Russ
Russ
Russ
Russ
