Need to Remove Glue
Old 01-15-2014, 02:21 PM
prestige6
prestige6's Avatar
Default Need to Remove Glue
Took up my front carpet,Bubba was in there and glued everything down.Have the carpet up and I'm scrapping the glue off the floor. Is there something I can spray on to dissolve the Glue so it scrapes off easily.
Old 01-15-2014, 03:16 PM
zangx1
zangx1's Avatar
I have used 3M adhevise remover with some success, but still need a lot of elbow grease also try mini grinding pads and wear a mask
Old 01-15-2014, 03:17 PM
pv
pv's Avatar
You can try 3M General Purpose Adhesive Cleaner p/n 051135-08984
Paul
Old 01-16-2014, 08:45 AM
Roger Walling
Roger Walling's Avatar
Received 1,595 Likes on 662 Posts
I found that a wire wheel works well, but messy, cover every thing.
Old 01-16-2014, 09:21 AM
wombvette
wombvette's Avatar
Bubba worked at the factory.
Ya know you cant see a bit of it. Why does it need removing?
Old 01-16-2014, 06:36 PM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
It needs removed because its probably keeping a lot of the foam backing stuff off the carpet stuck to the floor board ... went thru it in my '61. You just have to suck it up and scrape the snot out of everything. I use NO glue in my '61 when installing carpet not even one eyedropper's worth - not necessary whatsoever!
To Need to Remove Glue
Quick Reply: Need to Remove Glue
