Vacuum Advance
Old 01-15-2014, 05:07 PM
John A. Petrarca Jr
John A. Petrarca Jr's Avatar
Default Vacuum Advance
I have a question on ignition vacuum advance.
Why did GM use vacuum advance versus total timing?
I just figured out my timing issues on my "64" 300 hp,
the vacuum advance can was wrong.
Thanks, John
Old 01-15-2014, 05:13 PM
MikeM
MikeM's Avatar
Received 1,843 Likes on 1,398 Posts
Thanks, John
Your question is too vague for an intelligent answer.
Old 01-15-2014, 05:15 PM
JohnZ
Support Corvetteforum!
JohnZ's Avatar
Received 1,857 Likes on 1,100 Posts
Thanks, John
Read this - it explains ignition timing and how centrifugal and vacuum advance work together to optimize driveability and performance.
http://www.camaros.org/pdf/timing101.pdf
Old 01-15-2014, 05:25 PM
65 Pro Vette
65 Pro Vette's Avatar
Received 1,048 Likes on 576 Posts
C2 of Year Finalist (appearance mods) 2019
Thanks, John
Bottom line is at 32deg of timing you would never be able to start your car hot!! They are sometimes hard to start at 9deg (big blocks)
Old 01-15-2014, 05:38 PM
John A. Petrarca Jr
Thanks John,
The link explains how and why the vacuum advance was used.
Old 01-15-2014, 05:44 PM
John A. Petrarca Jr
Thanks, the hard starting when warm and other issues is why I went back to stock timing.
Putting the correct vacuum advance can really made a huge difference.
Old 01-24-2014, 09:33 AM
Robert Lewis
Robert Lewis's Avatar
Default Ignition timing part 2
John,
This is a really informative article! There's a reference to Part 2; could you point me to that? I haven't been able to find it by the search function.
Many thanks,
Rob Lewis
Old 01-24-2014, 01:34 PM
JohnZ
JohnZ's Avatar
Originally Posted by Robert Lewis
John,
Many thanks,
Rob Lewis
Yup - here's Part 2 about mapping advance curves:
http://www.camaros.org/pdf/map_advance.pdf
Old 01-24-2014, 04:20 PM
devildog
devildog's Avatar
Location: fighter pilots make movies, bomber pilots make history
John,
Do a quick search for Model T ignition or How to drive a Model T Ford. That is the simplest and most graphic way to explain spark ignition.
The computerize ignition on a new C-7 works the same way. Only the computer is doing all the optimization with more inputs than the Model T driver has with his seat of the pants and tweeking with his ears.
Joe
Old 01-24-2014, 04:57 PM
Robert Lewis
Many thanks, John. I'm afraid I'm going to have to pull the distributor (which scares the bejeezus out of me) and try the 180* turn suggested elsewhere.
Right now I've replaced the existing VAC (MS 360 12) with a B28 (this is a '65 327/365), but with the full vacuum line disconnected (15" Hg) I can't get the advance below perhaps 16+* (I've ordered a dial-back timing light to know exactly) with the VAC hard against the coil. Yes, the dwell is at 30 and idle is at 750.
So, wish me luck!
Old 01-24-2014, 05:40 PM
Robert Lewis
And yes, the full vacuum line has been disconnected and plugged, Plasticman.
To Vacuum Advance
Quick Reply: Vacuum Advance
