502 flywheel
Old 01-27-2014, 07:44 PM
BAMiller
BAMiller's Avatar
Default 502 flywheel
Can anyone tell me the part number for this flywheel, the casting number is 10101171. It came with a 502 a friend ask me to install in a 66 coupe. I am sure its a external balance flywheel it has the large weight on it but I have heard there are different flywheels for forged cranks and cast cranks. I think all 502 s have forged cranks but not positive. Its an older 502 casting number 14096859 no fuel pump or clutch bell crank provisions. It may have come from a boat have tried to get more info on what has been done to the engine but can not. Will be using a tremic 5 speed trans. Thanks
Old 01-27-2014, 08:03 PM
lakebumm
lakebumm's Avatar
2022 C2 of the Year Finalist - Modified
This may help.
http://www.nwoffshore.com/forums/showthread.php?t=1165
BILL
Old 01-29-2014, 05:14 PM
BAMiller
BAMiller's Avatar
thanks that is what I needed. I will have to take the pan off and try to tell whether I have a cast or forged crank and what pistons are in it. It has square port heads but the casting number says they are replacement heads casting number 14097088.
To 502 flywheel
Quick Reply: 502 flywheel
