1962 Corvette Complete Front and Rear Disc Brake Conversion kit
I have a 1962 C1 and I am looking at adding disk breaks.
Does anyone have advice or suggestions on disk break conversions?
1) worth doing?
2) suggested brands and kits?
3) install tips and tricks?
1) worth doing?
Adding front disc brakes really helps. Rear not so much.
ECI is one company that offers front conversion kits, as well as Master Power Brakes, and most of the Corvette supply houses have them.
As far as tips and tricks, depends on the kit you select to use. Beware that most (if not all) will change the track (offset the wheels outward a small amount). With original wheels, this is not really a concern, but if you have wider rims & tires, it could be a potential fender rub issue.
Recommend that you use the search function to look up previous threads on brakes (will keep you busy for a few "hours"!).
Note that there are constant discussions on the need for dual master cylinders, proportioning valves, residual pressure valves, etc. Wade through them at your own risk (after 8 years, I am still running the original single master cylinder, with no "extra" valves, with front disc, and the original rebuilt drum brakes). I have a dual m/c sitting on the shelf - just in case......
Also, any disc brake kit will require you to remove the master cylinder residual pressure valve (otherwise, you will be constatly dragging the disc brakes). Good time to rebuild the m/c (kits available from NAPA).
Also, all the front disc brake kits I am aware of will come with new front bearings, which will be tapered roller bearings. These are far better than the ball bearing that were "original".
Good luck,
Plasticman
Good luck,
Plasticman
A properly working drum system is a good system.
My '62 and my '67 both have rebuilt and correctly working factory braking systems, both non assisted and both cars are on radials.
My '65 Mustang has rebuilt factory non assisted front disks and self adjusting rear drums (GT), also on radials.
The '62 brakes like an antique car with four drum brakes, the engine power sometimes lulls you into forgetting you are driving an antique, but you have to be ever vigilant because the brakes simply do not brake the car as quickly as disks, and I find them difficult to modulate in panic situations, always a risk in modern traffic in a big city. They also require fairly regular adjustment, or they pull side to side, or can lock in the rear first, you sure don't want that.
The Mustang brakes straight and clean every time, feels like an older modern car, but does not fully have the braking power of a modern car due I guess to the smaller non vented factory disks with non power, and rear drums. Disks were pretty new on a lower cost mass produced US car in '65.
My '67 brakes straight and true, almost on par with my Legacy GT DD, a little bit different though because they are non assisted, but I think they are great the way they are and I never feel that I need more brakes or assist in that car.
If you are going to drive your '62 regularly, especially in traffic, and especially in traffic in the rain, front discs for sure, the fronts do 70%~80% of the braking anyway.
Paul
PS. The only reason I never put front disks on my '62 is because I have it judged, otherwise I would have done it years ago.
Paul
Good luck,
Plasticman
Good luck,
Plasticman
Great info, thanks! I think I am going to put them on the front this summer.
Dennis
It was done by the previous owner on the '61 so I don't know the details -- but the car now sports 1973 Camaro front disc brakes. I'll bet this route is 100's of dollars cheaper than some of the 'glitzy' kits sold commonly. Car stops as nice as you like.
My split window coupe has all drums, non power and EVERYthing newly rebuilt....it stops fine with that technology in normal traffic...but panic stops give you that millisecond of ***-clenching fear until the braking starts to take effect - which I can live without at my age.
Amen brother!
Also in '49 all the other cars braked, handled and accelerated similar to a '49 Chev or worse, and there were far far fewer cars on the roads...
Never mind cell phones, GPS, texting while driving etc, a very different world...
Paul
Paul
[QUOTE=Frankie the Fink;1586138165]It was done by the previous owner on the '61 so I don't know the details -- but the car now sports 1973 Camaro front disc brakes. I'll bet this route is 100's of dollars cheaper than some of the 'glitzy' kits sold commonly. Car stops as nice as you like.
I am also looking a discs for my 62 before taking a cross country trip in the spring.
I priced all the parts for a 1973 Camaro from Napa and using all the premium parts I came up with $328.01. The price does not include the caliper mounting brackets, that are included in all the kits. Where would you find the mounting brackets and will the brackets from a Camaro fit a 62 Corvette?
Regarding C1 rear discs, dont forget to check the Stickies at the top of the page - there's a good thread from "Mickatbp" with an assist from "wmf62": http://forums.corvetteforum.com/c1-a...os-please.html
Regarding C1 front discs, there's tons of info in the archives over the past 15 years, use the search button. We've seen kits of yesteryear with C2/C3 calipers & rotors all the way up to modern 13" rotors for 17"+ wheels. Most "new" kits offered within the past 5 years or so are still available and relevent today.
Another "plus" for the Camaro setup is that I don't run a proportioning valve. With the Camaro front discs and stock drum rears the '61 stops as nice as any conversion I've ever done when she digs her heels in...
