63 Windshield
Old 02-24-2014, 12:16 AM
deejaydu
deejaydu's Avatar
Default 63 Windshield
Who sells the correct and best Windshield rubber gasket for a 63 SW. I also need 28 new clips. Are they original style and do all the vendors sell the same ones.
Old 02-24-2014, 07:58 AM
Nowhere Man
Nowhere Man's Avatar
Received 6,943 Likes on 4,782 Posts
2015 C2 of Year Finalist
Paragon has the right clips.
Old 02-24-2014, 09:00 AM
gbvette62
gbvette62's Avatar
Received 2,029 Likes on 1,315 Posts
To my knowledge, the only company making Corvette windshield rubber, is Corvette Rubber. Most vendors carry the one from Corvette Rubber. If your not sure who's they are selling, ask.
I don't recall who makes the molding clips, but I'm pretty sure there is only one source for them also.
Old 02-24-2014, 09:18 AM
rayvaflav
Support Corvetteforum!
rayvaflav's Avatar
Are the ones from Paragon (the USA made kit) now the ones that will work correctly ? I remember over the last few years it seemed like none of the reproductions worked correctly. I'll be needed a set for my coupe as well.
https://www.paragoncorvette.com/p-35...kit-coupe.aspx
Ray
Old 02-24-2014, 09:53 AM
deejaydu
deejaydu's Avatar
Ray
Hello Ray,
That is the reason that I asked the question. We seem to remember the same thing. I hope that someone can tell us for sure. I had to remove my 63 SW windshield to find a water leak. I am pleased that the windshield frame is in excellent shape and I found the water leak where a very small area of the roofline was unbonded right where it touches the windshield frame. I think that I will be good to go after a correct reinstall.
I hope that you make it for Keels and Wheels this year.
Jay
gbvette62
gbvette62's Avatar
Ray
The ones in your link are for 64-67 Corvettes. The OP was asking about 1963's, which have a different windshield molding and use different clips.
The US made 64-67 clips that Paragon has, I think are the updated clips, that are supposed to work. I'm pretty sure that Long Island is the company that is actually making the correct clips. I would check with Paragon (or anyone else you might buy them from) to make sure that they are the better clips.
Old 02-24-2014, 10:05 AM
gbvette62
gbvette62's Avatar
Originally Posted by deejaydu
Hello Ray,
Jay
The problem with windshield molding clips, involved the 64-67 clips, not the 63's. The 63 has different windshield moldings, and uses a completely different clip. I've never heard of any issues with the 63 clips.
Old 02-24-2014, 10:21 AM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
I ordered my windshield rubber direct from Corvette Rubber. Not sure I'd trust a middle man to have them as the source. You have to be VERY cautious ordering the '63 window clips. I think there are at least two different types and they HAVE to be for a '63. Mine were back-ordered for quite a while but finally arrived. I'll try to find my invoices and post them here. You get the wrong thing and you're screwed.
This is what I found but IIRC there were two types of clips and I may have had to order them elsewhere...can't remember!
Old 02-24-2014, 07:39 PM
deejaydu
deejaydu's Avatar
Frankie were the clips that you ordered like the original clips and did they work well. Are the two clips used on the pillar moldings the same as the other 24 clips that are used on the top and the bottom. Do you have a picture that you can post that shows the correct placement for the clips.
Jay
Old 02-24-2014, 07:44 PM
Frankie the Fink
Army
I did not replace my windshield (yet)....since I was replacing the headliner anyway and had all the metal trim out around the windshield I put sealant around the perimeter of the windshield gasket-to-frame area by lifting the gasket up carefully. I think that will prob solve my leak. If not I'll deal with the windshield later on; that's why I have the clips and gasket in my spares locker.
Old 02-25-2014, 12:10 AM
deejaydu
deejaydu's Avatar
Frankie that explains why I did not see a post from you about your windshield removal yet. I now have mine out and have the frame all cleaned up and can clearly see where the leak is. It is where the roof bonds to the frame on the left side about 2 inches in. There is very clear separation with a small hole about the size of a BB and when I stick a small screwdriver in the hole it goes all of the way through. That might not be my only leak but it is definitely one for sure. I removed 30 clips so I know that somebody has been in there before. The clips are confusing to say the least. I might have to summons Jackfit on this one since he has been there and done that. Oh Jack where are you?
Old 02-25-2014, 06:08 AM
Frankie the Fink
Army
Here is what you need:
http://1963splitwindow.blogspot.com/...tion-1963.html
This article also states that Paragon may have the better fitting clips - so it might be "my bad" on that purchase.
We'll see... Note the number and types of clips shown - 30 on your car is too many it seems.
Old 02-25-2014, 10:50 AM
deejaydu
deejaydu's Avatar
Hello Frankie,
That answers all of my questions. I will get everything ready and do a trial fit of the clips and trim and then go for it.
Jay
Old 02-25-2014, 10:56 AM
Frankie the Fink
Army
If you can reciprocate by letting me know what molding tool you used to pull the windshield molding off I'd appreciate it. A picture or link to the product is fine.
I've never pulled molding off a vintage car and have NONE of the tools to do so.
It'd be nice to buy something knowing somebody else used it successfully for the same task on an SWC.
Old 02-25-2014, 07:33 PM
deejaydu
deejaydu's Avatar
Frankie I did not use a specific molding tool. With the help of a neighbor I used a very thin metal ruler along with two small plastic pry bars that he had. I then slightly heated the gasket and then slipped the ruler between the molding and the gasket and pushed in to release the clips one at a time. While I had the clip pushed in my neighbor slid either one or both of the plastic pry bars under the molding and gently lifted it up a little at a time. We took our time and never applied pressure to the molding until we saw it coming up and then we only used necessary pressure to remove the trim. The clips were only located on the top and bottom moldings. There were not any clips on the sides. I taped everything off before we started the removal. I do not have pictures of his small plastic pry bars that we used. We got the moldings off without any damage. I hope that this helps.
Jay
Old 02-25-2014, 08:23 PM
Frankie the Fink
Army
Well if you don't have a tool that you can share with me at least send your neighbor over for a day or two...
Old 02-25-2014, 11:39 PM
deejaydu
deejaydu's Avatar
Frankie I bet Mike Coletta would work out well filling in the neighbor role but in the meantime I will see if I can photograph my neighbors tools and post them up for you. They were absolutely perfect for the job. Thanks again for all of your help and the other forum members as well who posted helpful information.
Jay
Old 02-26-2014, 07:47 AM
Frankie the Fink
Army
Yeah - Mike is my "back up plan" when I fall flat on more difficult tasks. Don't go to too much trouble posting pics or whatever. I'm prob gonna leave the windshield alone unless I have massive leaks that my Bubba caulking job missed...
To 63 Windshield
Quick Reply: 63 Windshield
