steering wheel question
i got an ecklers steering wheel with new screws...
do i need a puller to take the old wheel off? 63 swc btw...
Jordan
ps. old cars confuse me lol
Jordan
2016 C2 of the Year Finalist
I'd say yes if you're pulling the wheel. Remove the horn button and contacts below and unscrew the nut. You might get lucky by pulling up on/working the steering wheel but I'd be surprised. I think you can rent a puller from Auto Zone or similar places.
If your '63 is like my '66 you don't need to pull the hub. Just gently pry off the button, remove the 3 contact screws, then remove the screws for the wheel.
Correct. You don't need the puller unless you need to get the hub off to get to the turn signal switch or something below. Don't remove the large nut in the center, just the phillips screws in the wheel.
