'61 Carpet Glue
'61 Carpet Glue
I have new tuxedo carpet for my '61. Various people through yesterday at an AACA show have told me to glue 0% of the carpet, just the center piece, and 100% of it (and a few variants). My judging book states "Original carpeting was glued to the floor ......". "Deduct on originality for loose carpet".
So what is the correct amount of the carpet to glue for a car that's going to be judged?
Received 1,857 Likes
Gluing carpet
At the all Corvette Show in Venice, FL talked to two guys with top flight cars. They had just fastened the carpet at the edges and hadn't done any gluing. Thinking I might put a small amount on the center carpet if it doesn't lay down but that will be it.
I've recarpeted my '61 twice in 12 years...top down driving in Florida is HARD on the color fastness. Never put a drop of glue anywhere...it simply isn't necessary.
BTW, if you use the 3M spray adhesive, be careful with it. Mask carefully. the overspray lifts lacquer paint.
I never glue itdown unless it's getting judged, then it'd be just the edges.
Once you get caught in the rain and have to pull it all out to dry it off, you'll be glad you didn't glue the main floor pieces down.
NCRS Point Deduct for Loose Carpet?
How much of a deduct did you take? I like the idea of not gluing since it's a driver and well - I've already had the rain thing twice. At least on the Gulf side of FL showers just seem to pop-up from no where, get you wet and then go away. So if the deduct isn't too much I'll live with it.
Hell put a little (1" maybe) of that Velcro peel & stick two-part tape on the carpet and floor at the judged points and nobody will know the difference...still easy to remove the carpet and no gooey mess.
The post about being able to get the carpet out to dry it off when it gets wet is also a good point.
