Trying To Get The Light in my Glovebox Working
I have the shield for the bulb there...wondering if I am able to replace just the bulb or do I have to replace the whole light (switch) thing? And, is that light switch hard wired to the car. If the bulb can be replaced, what size if it as I don't have the original bulb
The light switch is hard-wired to the factory harness. There's an orange/black wire (if I recall correctly) very small gauge wire that terminates in a special metal clip which inserts into the back of the plastic light switch. That metal clip serves as a the groove/notch the bulb slides/twists into.
This excellent info from DZVette shows everything you need
http://forums.corvetteforum.com/1586157240-post4.html
http://forums.corvetteforum.com/atta...amp-switch.pdf
Thanks...it was just a bulb...I was thinking it wasn't wired up...there was no bulb there...it is working now...of course, the box wouldn't open and I had to adjust the strike plate...but all is fine now...it's all these little things that need adjusting on a 50 year old car...but worth it in the end. I went to Starbucks to get coffee this morning as it was a sunny day at 58 degrees...5 minutes in the store. Came out and there were two separate people taking pics of my car..too funny...guess I better get used to that.
-Bruce
It's possible the bulb was removed because the switch doesn't turn off and the previous owner had a battery drain. Watch for that now that a bulb is back in.
