Winching into Trailer
Ok been thinking about this for awhile without much success so I thought I would ask the forum for suggestions.
I need to figure out how to winch my 62 restomod into an enclosed trailer - basically where to attach cable.
The car sits really low so I'm stumped on where to attach cable. Wasn't planning on running front plate or bumperettes but if I could attach cable to winch car on to it....
Can't drive the car in as its a hardtop only car and don't want to take hard top on & off when putting into trailer. My trailer doesn't have the side access door for but it wouldn't help any way as the doors would not clear the trailer inner fenders...
Any suggestions?
Any suggestions?
Winching.
Any suggestions?
Any suggestions?
Any suggestions?
Any suggestions?
First let me ask... Have you ever had your car in this trailer before doing a restomod to it? If so, is there much room for you to get around the car when in the trailer?
-Bruce
I have had the car in the trailer but there's not much room on the sides, its a standard hallmark 28' trailer. At that time there wasn't a motor or trans, interior or anything in to add weight to the car. Once done it would be too heavy to push in by hand. I have a wireless remote for my winch so I can walk along side it to steer and load / unload by myself.....just need to attach cable to car, probably going to use the front license plate / bumperettes area somehow....
I had slotted tie down brackets welded low on the front cross member to tie this car down in the trailer so we could race it. The trailer still had to be jacked up stupid high so the front pan would not hit the door hinge when winched in.
Bud2
My way.
With my '64 (the same????), I load rear first and so I installed a tow hook there. The bar bolted to the frame cross rail is the main strength, while the two side bars hold hold hook quite firm. The actual hook is a long bolt that is bolted to the end frame rail. Is that clear??? Seems to be strong enough.
These are the parts I made up.
This is the shot of the front section.
This is the back section.
And this is what shows.
I also had to build some ramp extensions from wood to clear when loading. I simply put the extensions on the end of the trailer ramps to raise them 6 inches. It all works fine. I also use a ****** block but only to ease the pressure on the winch's brake when I stop while mid-loading. I don't have pics of the extensions but can take some of you need a look.
Bud.
Bud.
My '59 restomod uses a C4 front suspension in front and it sits pretty low. I welded two brackets onto the bottom of the front cross member and I use them to attach the tie down straps. I can also winch the car onto my trailer using these brackets to attach the winch cable. I have an enclosed trailer also, but it has really good access to the front, side, and rear so access to the car after it is on the trailer is no problem for me.
Charles
1Cool60 - Winch is mounted on the floor.
Bud2 - might work but with a 28' trailer that would put a lot of weight to the back of the trailer and cause weight distribution problems.
cbernhardt - I am using an Art Morrison chassis with IFS (not corvette) and Ford 9" in rear.
Redbird; "drive in crawl out window" - Not going to play Dukes of Hazard with all the money spent on paint and interior, plus don't bend like that anymore….
63Corvette - I am using a 9000# warn winch mounted on the floor in a removable cradle so I doubt it will break the winch...
Thanks for all the suggestions but probably going to fab something up hidden behind the bumperettes, this would prevent damage to the paint & body. Might have to ask Herb aka FirstGear as his sits pretty low…..
Were you using an enclosed trailer or open trailer? With my open trailer I have to use longer ramps to get the angle to work but with my enclosed trailer the door flops down & loads with no problem, or did when building it, still to try with motor, trans, exhaust, interior, hardtop installed…
Could you send or post me some of your pics of the frame mounted brackets?
You know you have it bad when you study the pictures of somebody elses frame. Not to look for flaws but looking as it is a piece of art. Is there a cure for this?
I use a tow strap around the third member. Then I take a length of 4x4 that I have "customized" to fit under the front of the third member and radiator support area. The strap then attaches to the winch hook. With the strap under the 4x4, it keeps it low enough that it clears the lower fiberglass valance.
C2 of Year Finalist (appearance mods) 2019
Vetrod62-
