a couple of questions - shifter, tunnel insulation
Old 03-23-2014, 11:56 AM
myronf
myronf's Avatar
Default a couple of questions - shifter, tunnel insulation
I plan on install transmission tunnel insulation on my 65. It's all gone, but 3 out of 4 clips are there.
1. If I buy a clip can it be installed from below. Or do the 2 rivets get inserted from above? I am familiar wit pop rivets, but how do these work. Can I just jb weld the clip into place instead?
2. I assume that I can drop the shifter with out removing the console above. correct?
3. What are the bolt lengths that hold the shifter on to the 4 speed muncie in a 65? The top is long and bottom is short. My experience is that they are a bear to install.
4. Can I install the tunnel insulation with shifter out but trans in?
5. Besides the 4 clips (3 are still there) what kind of glue do you use?
appreciate the responses
Myron
Old 03-23-2014, 12:19 PM
66jack
66jack's Avatar
1. If I buy a clip can it be installed from below. Or do the 2 rivets get inserted from above? I am familiar wit pop rivets, but how do these work. Can I just jb weld the clip into place instead?...You can rivet it but it won't be correct..you can use some JB..clean the surface b4 you use JB...
2. I assume that I can drop the shifter with out removing the console above. correct? NO needs to be removed...
3. What are the bolt lengths that hold the shifter on to the 4 speed muncie in a 65? The top is long and bottom is short. My experience is that they are a bear to install....They are tough but can be done...the upper is the hardest, especially with the insulation in place...
4. Can I install the tunnel insulation with shifter out but trans in?...NO
I didn't glue mine in...just make sure its tight...others I've heard use some glue plus clip..
Myron
Hope this helps
Old 03-23-2014, 02:34 PM
myronf
myronf's Avatar
I was hoping that I could push the insulation in with the trans in place. Obviously it's not worth pulling the trans to do this.
Has anyone successfully done it with the trans in place?
Old 03-23-2014, 09:50 PM
KMS396
Support Corvetteforum!
KMS396's Avatar
I just did mine in my 65. I took the shifter out without doing anything to the console - just removed the ball, etc. I cant see how you'd do the insulation without removing the trans, as you'd slice the insulation to pieces on the clips when trying to squeeze it around the trans.
Old 03-24-2014, 03:43 AM
856666's Avatar
Default Installation
I cut the insulation in half and installed it with the trans in.
Phil
Old 03-24-2014, 09:19 AM
myronf
myronf's Avatar
Phil:
Did you leave the shifter in? Or drop it?
Myron
Old 03-24-2014, 09:55 AM
856666's Avatar
Phil:
Myron
Shifter In - not dropped
Phil
To a couple of questions - shifter, tunnel insulation
Quick Reply: a couple of questions - shifter, tunnel insulation
