Help finding a smaller diameter powersteering pulley for LS3
I need a smaller diameter pulley for the power steering pump on my LS3. I'm using the stock LS3 accessories on it and now the PS pulley hits the A-arm shaft and the bolt. Does anyone sell smaller diameter pulleys for these and how easy/difficult are they to change?
Current stock pulley is 6.7" and the one I need should be 5".
Try these guys, they build performance PS units right here in Saginaw Michigan, the home of power steering. Brian
http://www.turnone-steering.com/
If you change the pulley to a five inch you will be increasing the pump speed by about 25%. That's probably not going to be good. Too much volume and maybe too much pressure. There is bound to be a solution for your problem because there are loads of these cars running LS3's. I would start Google searching a little more.
Good Luck, Mike Richardson
