can parked position of wipers be any closer to base
Just wondering if you think I can adjust wiper arms to be in closer to the base of the windshield.'
http://web.mail.comcast.net/service/...=298421&part=2
To the OP, make sure that you don't set them so low that when the glass is wet, they hit your trim. They will make marks. There is also an adjustment screw on the arm itself that will make slight adjustments up and down.
Errrr...you read wrong. Not only can they lock up when used; the metal arms can get mangled and sweep across your hood and do a number on your paint. You need to fix it for sure
