Quck help please, assembling Muncie
Old 04-15-2014, 07:29 PM
00fxd
00fxd's Avatar
Default Quck help please, assembling Muncie
Just replacing the front bearing on my 21. I see that there is a thrust washer behind the bearing between the bearing and the input shaft gear. I do not see this washer on any exploded views or parts lists. Is it supposed be there? Thanks for any input.
Frank
Old 04-16-2014, 03:22 PM
pop23235
pop23235's Avatar
Received 1,019 Likes on 679 Posts
Without seeing, I'll guess likely no.
Old 04-16-2014, 04:12 PM
seventyls5
seventyls5's Avatar
You will need to leave it. If you remove it I would guess you will end up with the input gear touching the case or too much slack in the mainshaft. Are you sure you don't need to completely go through the trans if you are this far in? Bearing at the mid plate is probably rough if the input bearing is. New brass and seals throughout is always a good idea.
Old 04-16-2014, 04:20 PM
steampunk c1
steampunk c1's Avatar
The washer is a oil slinger as there is no oil seal in input shaft you may have a oil leak if it is not fitted.
Old 04-16-2014, 04:49 PM
JohnZ
Support Corvetteforum!
JohnZ's Avatar
Received 1,856 Likes on 1,099 Posts
Here's a photo of that input shaft oil slinger.
Old 04-16-2014, 05:00 PM
seventyls5
seventyls5's Avatar
The oil slinger on a Muncie is the nut that holds the bearing to the input shaft. What you have pictured adjusts the clearance between the input gear and the main shaft.
Old 04-16-2014, 08:26 PM
00fxd
00fxd's Avatar
Thanks all. I have been googling today about this and lo and behold I discovered a post from some years ago by our DZTom in another forum. Essentially [as JohnZ pictured] the slinger/spacer is up against the input gear as shown - looks like mine may have looked like that before [not now]. This part is not shown in most exploded views that I have found. As Tom stated in that reply, early trans's did not have it. The OEM # is 3925692/3925762 both of which are NLA. The front LH Thread nut is called, yes, wait for it, a "Gland" nut. It also works in conjunction with the LH Threads as an oil slinger. I need to find a supplier of said slinger/spacer and am having a bit of trouble at this time.
Frank
Old 04-16-2014, 08:30 PM
plaidside
plaidside's Avatar
Received 1,120 Likes on 550 Posts
Call Larry at D & L trans.
(631) 351-4837
Joe
Old 04-17-2014, 02:53 AM
00fxd
00fxd's Avatar
Thanks plaid, I have a couple of local leads but I really hate buggin' people for what I understand to be a $3. part tho I would happily pay a lot more to get rollin'.
Old 04-17-2014, 01:42 PM
JohnZ
JohnZ's Avatar
Here are the clearance spacers for the main drive gear - they're different than the oil slinger.
Old 04-17-2014, 03:25 PM
00fxd
00fxd's Avatar
Thank you John. I now see that I need both. Most exploded views that I have looked at show neither. Do have OEM part#s for these, or at least the spacer.
Thanks,
Frank.
Old 04-17-2014, 05:17 PM
00fxd
00fxd's Avatar
Just to continue floggong this horse ... Why in both of these excellent exploded views, do not show the shim but do show the slinger, which in some opinions are optional?
http://www.autogear.net/pdf/munciecat.pdf Item # B2-2 - part that looks like JohnZ's 1st pic. of slinger which I'm understanding is old style.
http://www.5speeds.com/mpower/MuncieCat.pdf Item # B3 - part that I have seen as a change up slinger.
JohnZ's 2nd pic shows both with shim and the later style slinger.
Gads....
Old 04-17-2014, 06:10 PM
midstyle
midstyle's Avatar
Thanks,
Frank.
Here's an NOS M21 input gear I bought off FleaBay about 8 years ago. I believe the slinger is part of the package, as the Rev 10-1-69 P&A30B parts catalog Gr 4.351 describes # 3925690 as '63-69 Corvette (26 teeth) w/slinger $40.05
Notice the slight scallop on the circumferential edge. Maybe this is to line up with something ? No mention of spacer rings; I'll have to dig into my Petersen's "Basic transmissions" book [1971].
somebody must be reproducing these slingers, as I've seen them popping up on eBay in the past month.
c
Old 04-17-2014, 11:59 PM
00fxd
00fxd's Avatar
c
Thanks midstyle, I'm sure the slingers are avail in the after market. The one on your shaft is the newer style[?]. And it seems like I'll need a spacer too, so I will place an order tomorrow now knowing what I am talking about [I think]. And wait ... pah ...
Thanks all, Frank.
To Quck help please, assembling Muncie
Quick Reply: Quck help please, assembling Muncie
