vintage air and wiring harness for 64
I have a gen4 Vintage air, and will replace the wiring harness on by C2/64.
Do I need the "harness without aircond" or the one with aircond?
Ecklers doing some great discounts this weekend, are their harnesses from Lectric Limited?
I just put Vintage Air A/C Gen IV in a non-A/C '63 with original wiring. The wiring is pretty simple for the aftermarket A/C. If your A/C is already installed and your car was non A/C to begin with then all you need is the non A/C wiring harness.
My car currently has a non A/C wiring with alternator on the passenger side. No A/C installed.
I would get the Lectric Limited non-A/C harness and just follow the Vintage Air directions with one exception. Get VAK-6365 harness, also from Lectric Limited, to move the alternator to the other side during your A/C install. Makes the wiring nice and clean with the proper connectors and wire gauges...
Received 6,943 Likes
2015 C2 of Year Finalist
Just a FYI the AC harnes is a separate harnes all together
