pilot bushing removal
Easiest way is with a slide hammer designed for the job. However, they are expensive.
Fill the hole with axle grease, then shove an old input shaft or plastic clutch alignment tool into the hole. The back pressure from the grease will cause the pilot bearing to slowly back out.
A very popular method is to tap the pilot bushing and thread in a steel bolt. Use a bolt long enough so that bottoms on the end of the crank and it will push the bushing out.
More info in the FAQ and archives. I believe the bolt is a 5/8 inch diameter, about 2-3 inches long.
Larry
Larry
Larry
Larry
I finally had an occassion to try the grease method last year. I found a long socket with the right outside diameter and put an extention on it though the inside of the socket - pumped the area full of grease - seated the socket - and tapped the end of the extension with a hammer. May have been luck but that thing popped out so fast I couldn't believe it.
2018 C2 of Year Finalist
St. Jude Donor '12-'13-'14-'15, '19
Sorry, normally I'm only this dense Friday through Wednesday.
2018 C1 of Year Finalist
I am assuming it is a good idea to replace the pilot bushing even though the engine really has no miles on the transmission? I did replace it recently. Wondering if this is like the gaskets where even though no miles it should be replaced.
Note that since the pilot bushings are fairly soft (bronze), a "tap" can be made out of a 5/8" (coarse thread) bolt. Grind the threaded end into a taper, and using a cutoff wheel, make a few length wise slots on the threads. Or just get a tap............
The tap method is by far the fastest (and cleanest) method of them all. I have heard of guys packing wadded up wet toilet paper, similar to the grease method.
There are times when a pilot bushing is so worn that I had to use a 3/4" tap to remove it.
Plasticman
Plasticman
Once the pilot bearing is threaded then the 5/8 bolt simply bottoms out against the crank and walks the bearing right out!
Takes just a few minutes to perform both steps.
Last week the pilot bearing in my LS crank wasn't coming out, no way. So we quickly spun this shaft out of some stock. I packed some grease in the cavity but all I have here is synthetic. 'Cuz I'm cheep, I'd heard about the wet tissue deal so I supplemented with some. The first test whack the bearing moved about 1/2 way out. Pack in some more wet tissue, another whack and out it came.
