My '67 Convertible Project...Build Thread
#121
I haven't covered the door sill yet, but I can't find the carpet support channel you're talking about...what does it look like?
#124
Received 6,929 Likes
2015 C2 of Year Finalist
Where's the Luggage stop
#125
One on each side. They are held in place with clips and provide a 'channel' for the wiring going to the rear.
#126
Couple more things done this weekend...dipstick tube painted and installed, oil filler tube painted and installed, thermostat and housing installed, and the carb cleaned up and installed. It's starting to look like an engine.
Also got the drivers side fresh air functioning correctly and mounted the dash wiring harness to the firewall...
Have to order a new alternator and voltage reg...the one I have in the photos is incorrect and won't fit. Next up is the clutch and throttle linkage, and then the battery and engine wiring harness.
#127
Need one
Thanks. I'll look them up for my next order.
#128
Idea for you Build the complete dash with pads and gauges on your workbench. Install the dash harness on the back of the dash along with the radio & clock and then install as a complete unit. It will be much, much easier than trying to work on your back installing bulbs etc.
#129
#130
Is that feasible? I haven't looked closely enough at the interior components to see how they fit together and attach to the car yet. If so, I'm willing to give it a shot. My last experience with the dash in a C3 was particularly unpleasant, so I'm willing to do anything to make it easier. Although with the windshield out, that should help things.
It is not only feasible on a C2, it's the way the factory did it.
#133
There is a great thread by Lars on how to put your dash in...
http://forums.corvetteforum.com/c1-a...d-process.html
Its a treasure!
Its a treasure!
#134
Be sure to order the correct speaker if you are using an original radio. Most of the after market speakers will damage your radio. No need to ask me how I know this... just say lesson of hard knocks
#137
I don't have an original radio for the car, so I'm going to pick up a decent aftermarket one from one of the vendors. Thanks for the heads-up, though.
#138
This week I made a road trip to visit my brother, who owns his own business doing tuning consultation, forced induction setups, and mechanical/electronic fuel injection systems. He was able to give me a hand with a work-around for my Vintage Air compressor brackets to work with the McJacks headers...
The master at work
Mounting area moved from the inner most bolt-hole to a tab that is welded on to the top of the flange. This will allow the bracket to be spaced out the correct 2" from the flange.
Finished product (minus paint). The new mount is not touching the header primary as it appears in the photo.
Now I'll break it back down, paint it black to match my other brackets and give it a cleaner look, and press on with the install.
The master at work
#139
OK so long time, no update. Things have been pretty crazy at work for me for the last couple months, so time to work on the car has been scarce. Still, I've been plugging away on it for an hour or two here and there when I can.
Engine bay as of today...still need to replace the alternator with the correct one, and I'm ready to install the clutch linkage now...
Vintage Air components are all in place...hoses routed...heater hoses hooked up...
And I replaced all the accelerator arm / rod components...
I'm waiting on a bracket for my PS pump to arrive, and then once that's mounted, I'll be ready to install the fan shroud, fan, and radiator hoses. Once that and the clutch linkage is finished, I'll probably start back on the wiring harness for the engine bay as well as the wiring for the Vintage Air...
