Building a scale `67 Corvette L-88 version of the $3.5 million car
#81
It may be the white radiator inspection stamp..... "16 CT" in a rectangle. But I thought that was only for aluminum Harrison radiators.
The BB radiators were Harrison, but copper/brass, and I don't recall that they used either of those decals or the stamp.
There's a small Harrison plate on the right, at the tank on the vertical edge.
Like this...
MK for manual transmission cars and the rad part#
Like this...
#85
Received 1,857 Likes
L-88's didn't use the same copper/brass radiator the other 427's used - they used a special wider version of the stacked-plate aluminum radiator used on small-blocks, very similar to the radiator used on the '65 L-78, which also required a unique radiator support. L-88's didn't use a shroud, either.
#87
Major failure with the chrome on the wheels.
I got them back, and apparently my release agent caused problems, and the chrome was bubbled in places. I have them stripped now though, and am sending them back. Hopefully I will have them back in a couple weeks. I never thought i would say this, but this might go to someone looking for a Christmas gift at this point. I never would have thought back in April that I would still be working on this one. Oh well. I`ll post an update as soon as I get the parts back. Some of the other parts I had sent look great, so I am hopeful!
#88
I actually stopped having parts chromed and switched to the Alcad products
#90
I have the wheels sent out again to be chromed. Once they are back and on, I will post completed pics and list the auction.
#93
Yeah, we will see. I see the FM die casts going for $500ish, and some asking as much as $3k on Ebay. I never had problems selling them before, but who knows in this economy.
#96
More on the on-going wheel drama.
I received the wheels, with the same bubbling chrome:
Soooooo
I just had to get this right. So lots of research with other resin casters, and a whole new master and new mold later, I am casting completely new wheels (in the foreground)
The primer is the master and the silverish one was a test with Spaztix before casting more of them. Making the new master actually gave me the chance to work out a couple little imperfections that were on the previous masters.
So the new wheels are off to be chromed as of this morning. Between the multiple shipments to the platers, a new set of casting resin, and a new set of mold silicon, these wheels are getting very expensive. I could probably have a set of full size 1:1 ralley wheels at this cost.
Soooooo
#97
Well, I just received the `67 wheels back from the chrome platers today. And the third batch is worse than the first. So the wheels will not work out. I hate to do this, but I will be putting the `68 style wheels on this, putting everything together, and then will post some finished pics, and maybe a link to the auction once I get it up.
#98
Received 6,943 Likes
2015 C2 of Year Finalist
why not use the bolt on wheels that come with the kit. that would look much better then the wrong hub caps
#99
Do you mean the stock turbine style wheels? I thought the 68 rallys, though they are not the 67 hub cap style, would look closer to the 1:1 car that I am trying to replicate. Do you think I should go with the kit stock wheels instead?
#100
Yeah go with the stock wheels that came with the kit. 68 on ralley caps stick out like a sore thumb on mid years. Real car or not
