Siphoning gas
Siphoning gas
Guys,
I have to remove about two gallons of gas that is left in my tank because I need to change my electric fuel pump. What is the best way to do this. I tried loosening the connection (hard line) but it only drips out. I was thinking of a shaker siphon. Has anyone used this or another method. (other then sucking a hose)
If he has a 53-62, then insert a hose into the fuel filler neck and suck it.
Edit: oops he updated his post and thus I have no experience with a shaker siphon and can not offer help with that one.
When I swapped out my gas tank I did what was recommended above by Hitch and Jeff. I jacked up the right side to move the last gallon or so to the left then took out the sending unit. I had a oil changing collection plastic tub underneath when I let the car down and it all drained out nicely.
