QA1s with mono composite rear spring
Old 06-12-2014, 07:53 AM
woodsdesign
woodsdesign's Avatar
Default QA1s with mono composite rear spring
Guys,
I have a 330# composite rear spring. Currently I am running Bilstein HD shocks. I still have a little bounce on some road conditions. Has anyone used QA1's with this set up with good results? If so which ones work the best. TS 403, TR 403 or the TD 403 are the choices I come up with.
I have heard good things about them and wanted to check here before investing. As they are a bit pricey.
Old 06-12-2014, 10:35 AM
biggd
biggd's Avatar
Originally Posted by woodsdesign
Guys,
I have a similar issue on my 67 Coupe but I have the replacement gray shocks. I asked about using Bilsteins HD's or sports and I've decided to go with the sports. Since you are using the HD's and still getting a little bounce I hope I made the right decision. I only ordered the rears so far. If I like them I will order fronts at a later date. QA1's are so expensive!
Old 06-12-2014, 11:53 AM
woodsdesign
I just checked with Summit's tech department. They recommended the TS 403's @ $155.00 each. They have 18 settings. Can't remember what the Bilsteins were. I don't think they are that much less.
Old 06-12-2014, 12:01 PM
biggd
biggd's Avatar
I bought Bilsteins for $90 each.
Old 06-16-2014, 09:52 AM
LCato
6th Gear
LCato's Avatar
Per Vansteel's advice - I'm running the QA1 TN403 (non adjustable) shocks in the rear with a Composite Spring and I'm completely happy. I'm also running a 255/45R17 tire in the rear - not sure how much that is a factor.
Old 06-16-2014, 10:38 AM
biggd
biggd's Avatar
Just installed my Biltein sports yesturday but had to go to my grand daughters baptism so I haven't taken it for a ride yet. I'll report back this week after I drive it.
Old 06-16-2014, 04:41 PM
woodsdesign
That is good information, thanks. Do those tires fit without any mods?
Old 06-16-2014, 05:04 PM
LCato
6th Gear
LCato's Avatar
No adjustments to the body, but I'm running Offset Trailing Arms which probably gives me another 1 inch of clearance. The true limiting factor of tire width came down to the distance between the Frame and Wheel Opening. We measured several times before ordering Wheels and Tires. I'm running a 17x8 rear Wheel with 5.5 inches backspacing.
Old 06-16-2014, 07:34 PM
SI67
SI67's Avatar
Maybe I should know this, but what do you mean by "replacement gray shocks?" Delco?
Old 06-16-2014, 07:55 PM
biggd
biggd's Avatar
Yes.
To QA1s with mono composite rear spring
Quick Reply: QA1s with mono composite rear spring
