Rear spring replacement
Old 06-12-2014, 09:28 PM
histoy
histoy's Avatar
Default Rear spring replacement
I'll be replacing the rear springs in a few weeks, so I've been reading some of the posts to prepare for the job. A couple have noted that using the stock bolts with the 9 leaf spring will make the rear end sit too high. Substituting 8" or even 10" bolts has been suggested as a cure for this. Do you guys recommend this initially, then switch to the correct length bolts later as the spring sags?
Old 06-12-2014, 09:59 PM
JohnZ
Support Corvetteforum!
JohnZ's Avatar
Received 1,856 Likes on 1,099 Posts
Depends which spring you start with - most of the no-name replacements (none of which have the correct number of leaves or configuration) come from Brazil, Pakistan, India, etc., and almost all of them jack the back end of the car WAY up in the air (which created the cottage industry for 8" and 10" spring link bolt kits).
If you go with the Eaton-Detroit 9-leaf reproduction spring, you can use the correct stock mounting parts and the rear ride height will settle to correct within 100 miles of installing it.
Old 06-13-2014, 08:29 AM
GUSTO14
GUSTO14's Avatar
Received 1,962 Likes on 1,283 Posts
Originally Posted by JohnZ
... If you go with the Eaton-Detroit 9-leaf reproduction spring, you can use the correct stock mounting parts and the rear ride height will settle to correct within 100 miles of installing it.
John, what's the best source for the Eaton spring?
GUSTO
Old 06-13-2014, 11:23 AM
dkleather
dkleather's Avatar
2016 C2 of the Year Finalist
Order right from the factory......http://www.eatondetroitspring.com/
Old 06-13-2014, 01:35 PM
JohnZ
JohnZ's Avatar
Correct! When you get Mike Eaton on the phone, order your spring without paint - saves you the trouble of stripping the black shipping paint off of it when you disassemble it before you paint it gray and install a set of Quanta liners (if that's your plan); otherwise just install it and remove the shipping clips.
Old 06-13-2014, 06:30 PM
histoy
histoy's Avatar
Thanks for the info guys. I had already purchased a "no-name" spring from Corvette America, so I guess I'll go to Fastenal and pick up a pair of 8" bolts & nuts.
Old 06-13-2014, 07:25 PM
65hihp
65hihp's Avatar
Received 3,263 Likes on 1,686 Posts
that was only 21 hours from the time you first asked for advise. No one can say that you over think this stuff....
Old 06-13-2014, 09:08 PM
Nowhere Man
Nowhere Man's Avatar
Received 6,922 Likes on 4,771 Posts
2015 C2 of Year Finalist
if you look at the specs from GM good old hard wear store bolts wont cut it
Old 06-13-2014, 10:00 PM
histoy
histoy's Avatar
Excellent point. Fastenal has been able to supply me with all the correct strength hardware I've needed for any of my old car projects. I plan to take an original with me and have them get me a longer one with the equivalent strength. They'll have time to get me what I need because I probably won't get to this project until after we return from Bloomington Gold.
To Rear spring replacement
Quick Reply: Rear spring replacement
