Electronic ignition
Old 06-22-2014, 09:12 PM
64tux
64tux's Avatar
Default Electronic ignition
Do any of the electronic distributors have tack drive that fit the c-2's cable??
Old 06-22-2014, 09:19 PM
66jack
66jack's Avatar
MSD #8572 fits perfectly under the shielding, also, its what I'm running...
Old 06-22-2014, 09:30 PM
64tux
64tux's Avatar
does your tack cable fit in the distributor???
Old 06-22-2014, 09:39 PM
65GGvert
65GGvert's Avatar
Received 3,206 Likes on 2,297 Posts
Just asking, you do know you can change over to electronic ignition and still use the stock distributor?
Old 06-22-2014, 09:43 PM
64tux
64tux's Avatar
i know that, but my distributor is getting pretty worn out. i'd have to get it overhauled. figured it would easier to just get a diff. dist. thanks
Old 06-22-2014, 09:45 PM
66jack
66jack's Avatar
Yes, it fits...its made for Corvette..bought it from Summit...
Old 06-22-2014, 09:50 PM
64tux
64tux's Avatar
Thanks. can you tell me what else you had to change? like a better coil, or different resister, or a filter, different plug wires
Old 06-22-2014, 09:51 PM
Nowhere Man
Nowhere Man's Avatar
Received 6,920 Likes on 4,770 Posts
2015 C2 of Year Finalist
And this my friend is what's driving the off shore market for all the people with old cars. The fun in owning a old car is to rebuild original parts and reuse them. And really unless you got some over done high horse power engine you will not see or feel no difreance between points and your new wiz bang gadget. It's been beaten to death on here
Old 06-22-2014, 09:54 PM
64tux
64tux's Avatar
if its been beaten to death, why are you still BEATIN IT?
Old 06-22-2014, 10:03 PM
66jack
66jack's Avatar
This is what I'm running on my car...
I never had an original setup so I opted for this setup..
Had some engine work done...
Other than this the engine is stock/period correct...
8572 Dist
6A box
Blaster 2 coil...
8.5 mill plug wires
"Resister is eliminated"...
Old 06-22-2014, 10:07 PM
64tux
64tux's Avatar
8572 Dist
6A box
Blaster 2 coil...
8.5 mill plug wires
THANKS, 64tux
Old 06-22-2014, 10:46 PM
Thorson
Thorson's Avatar
C2 of Year Finalist (appearance mods) 2019
I use this same system on my '65 L78. The original TI was long gone when I got the car. The 8572 and Blaster 2 coil fit under the stock shielding with no problem. I painted the 6al box black and velcroed it to the passenger side splash shield. Wired it to the starter from there.
Old 06-23-2014, 10:06 AM
64tux
64tux's Avatar
Thanks for the reply! thats probably the way i'l go.
Old 06-23-2014, 12:08 PM
vettsplit 63
vettsplit 63's Avatar
Location: "You may all go to Hell- and I will go to Texas- Davy Crockett
St. Jude Donor '12
I hadn't thought of that-- thanks!
Old 06-24-2014, 11:11 AM
64tux
64tux's Avatar
after thinking it over i'm sending my dist. to Lars.
Old 06-24-2014, 11:54 AM
66jack
66jack's Avatar
What happened...someone shame you into it?
Old 06-24-2014, 12:07 PM
lars
Support Corvetteforum!
lars's Avatar
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,915 Likes on 1,928 Posts
I can fix your stock distributor up to run with any aftermarket unit. For some photos, you can check out this thread:
http://forums.corvetteforum.com/c3-t...e-them-in.html
Lars
I think he just wants something that runs really well...
To Electronic ignition
Old 06-24-2014, 12:44 PM
66jack
66jack's Avatar
Lars
Just ribbing him....
Old 06-24-2014, 12:58 PM
vettsplit 63
St. Jude Donor '12
Just to be sure I understand correctly- do you mean that you velcroed it to the shield that bolts up under the fender well and has the rubber weatherstrip stapled to it? Then just lay the box on top? I test fit my Mallory Hyfire IV box in there last night, and it is super close. It looks like it will fit, but I think you could paint it fluorescent orange and no one could see it; it is under the battery.
Old 06-24-2014, 02:41 PM
Thorson
Thorson's Avatar
Yup, that's the spot. It's a little more visible on mine with the battery on the drivers side. Also it's visible from the outside through the fender vents. Painted black, you really have to be looking for it to notice it.
Quick Reply: Electronic ignition
