Battery Removal
C2 of Year Finalist (performance mods) 2019
Battery Removal
1966 vert, L79, aftermarket a/c with battery on drivers side. My battery is at least 3 years old but probably much older. I would like to replace it. The opening to get the battery out does not look large enough. I am afraid of spilling battery acid as it looks like the battery will have to be rolled over on its side. The clutch rod and master cylinder are in the way. So, any advice on removing the battery? Thanks
Received 6,944 Likes
2015 C2 of Year Finalist
Did they not cut out the the inner fender like factory AC cars and have a bolt in door
Received 2,130 Likes
2015 C2 of the Year Finalist
Dan
If you're worried about acid keep some baking soda on hand.
It is a bit of a pain in the arz. Jack up the left front, remove the l/f tire, remove the access panel (eight bolts). You're not going to want to do this very often so spend the money for a good Group 24 battery. I chose a Delco 72 month guaranteed replacement battery and I keep it hooked up to a Battery Minder. Also, if you don't have one already, invest in a battery cutoff switch to attach to the negative side of the battery and keep it unscrewed when storing your car. New battery will have a sealed top, so negligible chance of spilling any acid. I like the above advice of wrapping the old one in plastic before attempting to remove if it has battery caps.
The battery in the car is fine now but I will change it within the next 60 days. I have decided to put an Optima group 24 red top. In doing research on batteries, I think the odds of a battery blowing up is less with an Optima. I had a group 31 Interstate blow up last weekend on my boat. I do not want to experience that again. The boat now has three Optima group 31 blue tops. There was no damage to the boat because the explosion was contained in a compartment. It was a mess to clean up, 6 boxes of baking soda.
Any battery can explode. The best way to avoid it is to maintain a proper charging system including good, clean connections.
Dan
