63 FI start up help
63 FI start up help
I have a 63 FI coupe, a barn find of sorts. I had the FI unit refurbished by a senior Rochester technician. I have installed the unit on the car. I have the intake duct, filter and mounting installed. I have set the idle speed, the idle fuel, and the fast idle speed. The fast idle speed setting is off the cam, and the engine will idle at about 700 RPM with a lopey beat that sounds like it's about to stall and then kicks over. So far so good.
The instant I add a touch of throttle to back out of the garage, RPM jumps to 2500 and won't back down. Throttle linkage was my first guess, but it seems free and the return spring is plenty strong. Blipping and releasing the throttle does not drop RPMs. Driving this thing around the block requires a strong foot on the brake. This is all with a warm, but not hot, engine
Background on the car...
NOM, 3959512 engine
unknown camshaft (makes lash setting tricky...)
solid lifters
Newly rebuilt Don Baker distributor
Any suggestions?
NOM, 3959512 engine
solid lifters
Any suggestions?
Received 6,528 Likes
C2 of Year Finalist (track prepared) 2019
If the fast idle cam isn't the culprit, then I'd suspect worn air meter bushings and/or a worn throttle blade shaft. Can you grab the throttle bellcrank on the side of the FI and force the idle back down to 700 RPM?
Another possibility, although an unlikely one, is that the throttle blade is hanging up on the gasket for the Air Meter. Strange, but I've seen it happen.
Jim
Jim
63 FI Start up help
[QUOTE=jim lockwood;1587239268]When this happens, have you looked at the fast idle cam to see if it might have rotated back into position?
Jim
QUOTE]
Thanks, Jim,
The fast idle cam is clear of the adjusting screw, and the linkage moves freely. I checked the air meter gasket, and it's fine as is the air meter shaft. I tinkered a bit with the idle speed setting. It was cranked down hard. I loosened the idle speed screw a bit, and this seemed to make a difference. Idle is now a sedate 700.
I still have a bucking problem idling around the block, and the the valve train is pretty thrashy. Next job is to figure out what camshaft I have. i bought a dial indicator and will try to measure the lift.
Jim
QUOTE]
Thanks, Jim,
Received 1,843 Likes
[QUOTE=Gene jockey;1587240710]
I would suggest you set the idle speed at 750 after you hook your vacuum advance to manifold vacuum rather than the oem location coming off the air meter pipe.
Jim
QUOTE].
Thanks, Jim,
Jim
QUOTE].
Thanks, Jim,
St. Jude Donor '07
[/QUOTE]I still have a bucking problem idling around the block, and the the valve train is pretty thrashy. [/QUOTE]
as good natured as they may be, they are not torque monsters and, depending on gear ratios, they really don't cotton to '"idling" around the block'...
Bill
Bill
63 FI Start up help
St. Jude Donor '07
[QUOTE=Gene jockey;1587244024]
see where the brass plug is in the upper right; this is the best and usual place for full manifold vacuum.
Bill
OOPS: generational problem..., right pew, wrong church.... C1 not C2
Bill
63 FI Start up help
Thanks, Bill, Jim and Mike. My set up is very much like yours, Bill, with one big exception. I have an aluminum plug (9/16) on the upper back side of the FI box. More important, I have a big hose attached to a fitting screwed into the side of the FI box. This hose points directly to the pipe to the PCV outlet on the block; I have one of the famous 3959512 engines with a big hole. I assumed that the hose from the FI box went to the pipe for the PCV. It looks like it belongs there. I can imagine this affecting all sorts of things. I also have an oil filler tube that is ported to the crank case, so that may be redundant.
There is a vacuum port on the left, top rear of the plenum. You can tap in there for vacuum advance. That's normally the vacuum source for power brakes. You can buy a fitting from some of the vendors with the right size nipple. I think the original application for that fitting was for pass car WSW,s.
The hose nipple from the oil fill tube should route a hose to the air cleaner adaptor.
Right hand rear of plenum should have a 45 degree fitting with a PVC valve and a hose to the rear of the block fitting.
Maybe someone can post a picture of this.
St. Jude Donor '07
i presume this is the plug you are talking about, it can be used if you have room with the ignition shielding in place.
or, you can get creative as i did and solder a small piece of the right size tubing to fit the vacuum advance hose into the side of a 90degree fitting to serve a dual purpose.
Bill
Bill
63 FI Start up help
My car has the 45 degree fitting. I was confused about the hose and its purpose. I am ordering a PCV valve from one of the vendors, along with appropriate hose to get to the aluminum pipe for the PCV fitting.
While I'm shopping for plumbing parts, how do I harness all of this vacuum to the vacuum canister?
Thanks for your support!
Once I get this done, I guess
St. Jude Donor '07
Bill
It's sounding like you didn't have a valve in your system?
St. Jude Donor '07
The correct PVC valve threads into the 45. The other end of the valve has a hose nipple on it. A short hose runs between the valve and the metal tube that pushes into a rubber grommet in the large hole in the block.
Bill
63 FI Start up help
Yes, indeed, it would explain it. I stuck a bolt into the hose from the 45 degree angle to plug the PCV line, and that helped. I'll let you all know how the PCV valve affects the idle once it arrives.
63 FI Start up help
The engine is well heaved under acceleration load, but it still bucks when creeping in traffic.
Also, 700 rpm idle speed is too low and can cause the bucking. Change the advance and set the idle to 750 and you should be in business if everything else is up to snuff.
