63 Transmission question
Old 07-04-2014, 08:44 PM
prestige6
prestige6's Avatar
Default 63 Transmission question
When did they switch from a borg warner trans to a muncie trans.What Month and what serial number. My car was built april 30th so i guess the borg warner is correct..
Old 07-04-2014, 08:52 PM
327carguy
327carguy's Avatar
The change is reported at approximately vehicle VIN 15000. That would have been mid May.
Hope that helps.
Old 07-04-2014, 09:39 PM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
My approx May 29th split window coupe has the Muncie.
Old 07-05-2014, 12:13 AM
TC233
CF Senior Fox Bat
Support Corvetteforum!
TC233's Avatar
My far older and mature car of May 27 has the muncie too
Got any E stuff for sale Frankie? PM me if you have any dated stuff thats falling off the car
Old 07-05-2014, 02:59 AM
rick charles
rick charles's Avatar
Default early
MY CAR BUILT APRIL 15 th # 129XX HAS A BORG WARNER T 10....
Old 07-05-2014, 08:16 AM
Frankie the Fink
Army
Not happening my friend. This car is original right down to the GM numbered wheel cylinders and spare tire tub lock. The very few things I've pulled off it are restored, bagged and tagged for posterity. Headliner, headlight motors, original carb/manifold, radio/speaker, Muncie side cover, heater box, etc..
Don't know exactly why though (same thing on my '61) -- that's just the way I roll
Old 07-05-2014, 09:39 AM
jfr's 63swc
jfr's 63swc's Avatar
My May 15, #15192 has a Muncie.
Old 07-05-2014, 09:48 AM
prestige6
prestige6's Avatar
Hope that helps.
My vin is under that,So I guess it's correct..
Old 07-05-2014, 11:01 AM
Frankie the Fink
Army
There is NOTHING wrong with the B/W T-10 tranny my friend. Those of us with early Muncies have some issues to deal with you do not. One example is the peened over stand off through the side cover that holds the rooster combs for the shifter lock out. When the peening wears off eventually and parts slide off you get a lot of nice big metal pieces washing around in your gears. That was later replaced with a stand off secured by a C-clip (mine has this upgrade now as shown in the pic).
Also the Muncie countershafts are notorious for leaking but that can be dealt with pretty simply but somewhat Bubba-style.
To 63 Transmission question
Quick Reply: 63 Transmission question
