Has anyone with power windows converted to manual?
Never have seen anyone try that before. I have read a couple threads where someone had a motor that died on them, or so they thought, and had a tough time getting it all out of the door but most times there is a problem with PW, it's not the actual motor that's the problem. It's usually poor connections in the wiring harness or the console mounted switch. If you have PW and have checked all the major components, it should be practically faultless.
Mike T - Prescott AZ
Way more trouble than it's worth to create a hybrid just to cover the odd instance when a part might fail IMO
