Intake manifold and vent tube question
Is the 300HP Crankcase metal vent tube shorter than the 350HP vent tube? The reason I ask is that I plan on replacing the non original spread bore manifold p/n 3927184 and Rochester carburetor on my 1966 SB for a Edelbrock 2703 manifold with a Proform or Quckfuel 600 cfm carb. Just trying to get all my ducks in a row before I start taking things apart. I use this car as my daily driver. Also, I would like to find hard fuel line from pump to carb that would fit with taller manifold. I hate wasting time and $$ on parts that don't fit. Any assistance would be appreciated.
The 300 horse tube:
https://www.paragoncorvette.com/p-35...327300-hp.aspx
The 350 horse tube:
https://www.paragoncorvette.com/p-35...50-365-hp.aspx
Received 2,126 Likes
You may need to replace your fuel pump with a unit that accepts a hard line connection. I changed my pump in order to use a hard line to my AFB carb. Dennis
Received 1,856 Likes
You'll need to fabricate a pump-to-carb fuel hard line - no aftermarket Holley carburetor has the same fuel inlet arrangement as the 3367 carb used on the '66 (or the 3810 carb used on the '67).
