New Corvette Tool - Guess what it's for ?
Too funny all these guesses. I think you should have let it run for a couple of days...cause reading all these were funnier than sh*#!!!!
This was the result of a conversation I was having with Rich over the phone and saying there has got to be a better/easier way to install these things and we were throwing all sorts of crazy ideas out there....and the light bulb went on for Rich.
I still like my idea of loading the plug on the end of a shotgun shell and firing it into the hole. But Rich didn't think that was such a great idea....go figure.
okay, okay, Roy.....You made me give in before I went to bed.
I chuckled when I read yours Russ, but then I thought about it. It starts use as a Female, then ends up being a Male. So I guess it's........ Transvestiteish.
Whenever I restore a car and get the firewall insulation I dread the fastener task. Over the years I've tried different methods, but always seem to need another person out front while pushing the plugs inside with the "push-tool".
I mostly work alone. This lets me do it easier and faster. It took me longer to make the tool than it does to install the 11 plugs with a helper. But now it'll be a lot easier for me with the tool.
Rich
p.s. BTW, the Winner of the guessing game was DZVette !! He emailed me right after I posted the thread and got it immediately. Thank Dave for letting us have some fun.
Dave, what kind of Prize would you like? Remember now.....We're in a Family Forum!
Should of gotten patent first somebody goanna steal it.
I was thinking of that yesterday, so this morning I'm starting the process. Maybe it'll be good, maybe not. It's a real niche market tool for a very limited application, but may be interesting to see where it goes.
The last time I applied for a patent it took 2 1/2 years and tens of thousands of dollars paid by the company I worked for at the time. Then the patent office rejected it because they had no clue about the design. Re-submitted it with a enhanced description and clearer differences to their prior-art comparisons, and then they approved it.
I'm also going to talk to the parts suppliers and see if they have any interest. If they do, I may get some made outside at a REAL machine shop. I'm just a "machinist-wannabe".
Rich
Rich
Dang it that's what I was just going to say it was for No prize ? by the way my 55 uses metal ones not rubber and I think up to 58
Hmmm, metal insulation fasteners? Really? The '56 I have here has it's original insulation and fasteners and they're rubber.
Hmmm,
I am going to ahve to make one of those, I have been fighting a couple rubber retainer plugs on the '72 by the steering column.
Thanks!
Doug
Thanks!
Doug
add.....If it's really different from these here, maybe I could make a new size tool here and send it to you to test out for me.
Thanks,
Rich
Rich
Rich
If you're selling them I'm a buyer! I've got to do this on the 57 when it comes back from paint.
After fighting with the ones on my other vettes, this would be awesome since I'm always by myself in the garage as well.
I'm voting for a group buy on here!
Anyone else second the motion?
Will do on the hole diameter and rubber gizmo dimensions.
I am thinking that a piece of thin wall steel tubing with a hole cross drilled in one end may work for one time small jobs, vs something you use a lot.
Is there a definite purpose to having the hole 1.25" deep, vs open ended?
Doug
Doug
#33
Maybe I'll make a few and you guys can pass them along to whover needs it when you're done, or send back to me if nobody needs it at that time.
Doug
Doug
Yes I had the thinwall tubing idea too for the simplicity, but the tool needs to be the right diameter to fit the holes, with the right ID for the plug tip to fit, and most importantly to "release" properly. I think standard tubing "off-the-shelf" will not fit and work right, that's why I made a prototype. there are a few "features" of the design I haven't divulged at this time.
Open ended could work, but strength is a issue when pushing it the plug. I broke my first aluminum prototype. Yes the depth on this one has a purpose, mainly to prevent "punch through" of the tip when being inserted in the tool.......it bottoms out the tip to help prevent that.
Thanks Guys,
Rich
#34
Sounds like a good idea... add it to the Corvette Brotherhood lending library!
I am loaning out Seat Stuff etc etc... take a look!
#35
#36
Great idea-good luck with your business plan!
Mike
Mike
#38
Cool Tool but As I recall last time I did this I simply took a slim screwdriver with round shank and ground a blunt end on it, inserted it in the hole in the head of the rubber plug, put some silicone on the pointed end of the plug and pushed it right through with the screwdriver tool. As I recall it was very easy to do by myself. I believe that is what the hole is for.
#39
What an absolutely great idea. I'll be needing me one of those in another month or so, so if you are renting, or selling please let me know.
Thanks,
RK
Thanks,
RK
#40
